72 john deere 820 3 cyl
   / 72 john deere 820 3 cyl #1
jww1960
john deere 820
tractor sat 10 yrs. changed all fluids, filters, lubricants, new batter she fired right up..12 hours later she went sluggish and quit, sit 5 min it will start run 10 seconds and quit. 12 v to solenoid, it clicks, fuel to injectors, fuel flowing thru pump back to tank, standyne injector pump 1987, tried a lil starting fluid to try to keep her running it does nothing...what am I missing...
   / 72 john deere 820 3 cyl #2
The return line on top of the pump.. remove it..
If it has a checkball fitting on the top cover, remove it also..
with the line off and the connector off, go ahead and start it.. now piece by piece, reassemble it.. waiting for a 10 count before assembling the next piece..
Once u find the piece that shuts the motor down, clean it and repeat the test..
Good luck
will do, but I pulled that line off and am getting fuel out of it going back to the tank. if something was going on in there wouldn't it effect the fuel flow..? thx, I am gonna try what you said as because I was getting flow I did not take the check valve apart.
   / 72 john deere 820 3 cyl #4
Yes, take the fitting off the top cover.. if done correctly u will b looking into the hole in the cover ..
NOW, try to start it.. fuel IS GOING TO flow out so b prepared for that, if need be, put a pan underneath the machine..
Good luck
Good luck
well I'll be darned...took the return line off there were 2 fittings connecting it to the ip, took them apart and could barely blow thru it, took a wire cleaned it out good reassembled, running like a top. I appreciate you very much for the help.
   / 72 john deere 820 3 cyl #6
Your welcome..
If it keeps happening, the pump will have to come off for a rebuild..
2004 Chevrolet Silverado 2500HD Service Truck (A55788)
2004 Chevrolet...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
GRINDER (A55745)
GRINDER (A55745)
Sunflower Yard Decoration (A55758)
Sunflower Yard...
2021 BOBCAT T595 SKID STEER (A52706)
2021 BOBCAT T595...
