730 loader hydr pump
/ 730 loader hydr pump
Okay got the thing fixed and working. I put a spacer inside the coupler hub from the tractor and the pump coupler. With the spacer against the end of the pump shaft and against the front of the drive coupler there is no wear as they turn as a unit. Again thanks for all your help. Now I hope at some point I will be able to pass on that help and help someone else.
MACK
/ 730 loader hydr pump #13
Just saw your post, I also have a 730 loader and I'mabout to install it on a 3000. There are 3 different lengths of driveshafts; you may need a longer shaft for your particular tractor. Make sure you use a high quality spline grease to prevent early wear on all of the splines. Do not use wheel bearing grease or any other typical grease. It will only heat up, turn to liquid, and get flung all over
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
John Deere Gator (A60463)
John Deere Gator...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2025 Pabreak 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
