7308 bale spear
   / 7308 bale spear #1
elbmas
south Jersey
2004 NH TC29D
I am looking for a bale spear that will attach to my 7308 FEL. Have found plenty for the 3 point hitch, but would like one set up for the loader. Any good info would be helpful. I have a 2003 TC29D tractor. Thanks /forums/images/graemlins/confused.gif
   / 7308 bale spear #2
What do your bales weigh? Moving round bales with the 7308 may be asking too much from that loader since its capacity is only 880 lbs.
   / 7308 bale spear #3
I bought a bucket bale spear from TSC.. had to drill one hole in the bucket.. the only thing that's a bug.. I have to take the tooth bar off to put the bale spear on.
   / 7308 bale spear
The bales are 4 footers, and weigh about 700 pounds each.
   / 7308 bale spear #5
Try Tractor Supply or your local Co-Op
   / 7308 bale spear #6
I believe we got a universal pin on spear from tsc a few years back. I don't suspect one which bolts on the bucket will be much good as you have the bucket pluse the added two feet of distance to the bale and the bale. I would ask a few dealers for some universal pin on stlye and stay away from the bucket type. Just my .02. /forums/images/graemlins/ooo.gif
   / 7308 bale spear #7
I read my 7308 manual a few nights ago. It listed the capacity at over 1000lbs. Did I miss something?
   / 7308 bale spear #8
</font><font color="blue" class="small">( I read my 7308 manual a few nights ago. It listed the capacity at over 1000lbs. Did I miss something? )</font>
The single bolt-on style concentrate all the weight of the bale on the front lip of the bucket. This can be hard on the bucket. As well, the bale itself will be extended 4 feet _in front_ of the bucket, using the old geometry stuff we thought we learned that means a loader rated at 1000# will not be able to lift a 1000# bale - perhaps not even close to that..... The closer the bale is in to the tractor, the more hay can be lifted.
--->Paul
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A56859)
2023 Fat Truck...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
Caterpillar 48in Forks and Frame Loader Attachment (A56857)
Caterpillar 48in...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
250 GALLON FUEL TANK (A58374)
250 GALLON FUEL...
