7308 leaking hyd fluid--bad!
   / 7308 leaking hyd fluid--bad! #1
back_the_pack
Western NC
1998 NH 1920 4x4
I have sprung a major leak at the quick connection between my joystick and loader (at the quick connects). The problem is missing o-ring in one of my connections. Where can I get a replacement, and what size is it? Any help would be great. My bucket is hanging low and looking pretty sad!
Well, I have read where you can get these at the auto parts stores, but what size am I lookin for?
   / 7308 leaking hyd fluid--bad! #3
It is easy to remove another one from one of the lines. Just use a jack knife or scratch awl to remove.
Would that one not then leak?
   / 7308 leaking hyd fluid--bad! #5
The new holland part # is 122056 it is an odd ball metric size but maybe auto parts could match it up for you.
   / 7308 leaking hyd fluid--bad! #6
</font><font color="blue" class="small">( Would that one not then leak? )</font>
Yep, both will leak until they are replaced. If your bucket is on the ground, leakage should be minimal until you can get them replaced.
   / 7308 leaking hyd fluid--bad! #7
Any ball bearing supplier in your area will have them. just check your local listing for bearings an give them a call. I recommend taking one in from another coupler so that they can use a micrometer to check the size. Maybe get a couple of spares as they are cheap. /forums/images/graemlins/grin.gif
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
golf cart (A56859)
golf cart (A56859)
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
