7308 leaking hyd fluid--bad!
   / 7308 leaking hyd fluid--bad! #1
back_the_pack
Western NC
1998 NH 1920 4x4
I have sprung a major leak at the quick connection between my joystick and loader (at the quick connects). The problem is missing o-ring in one of my connections. Where can I get a replacement, and what size is it? Any help would be great. My bucket is hanging low and looking pretty sad!
Well, I have read where you can get these at the auto parts stores, but what size am I lookin for?
   / 7308 leaking hyd fluid--bad! #3
It is easy to remove another one from one of the lines. Just use a jack knife or scratch awl to remove.
Would that one not then leak?
   / 7308 leaking hyd fluid--bad! #5
The new holland part # is 122056 it is an odd ball metric size but maybe auto parts could match it up for you.
   / 7308 leaking hyd fluid--bad! #6
</font><font color="blue" class="small">( Would that one not then leak? )</font>
Yep, both will leak until they are replaced. If your bucket is on the ground, leakage should be minimal until you can get them replaced.
   / 7308 leaking hyd fluid--bad! #7
Any ball bearing supplier in your area will have them. just check your local listing for bearings an give them a call. I recommend taking one in from another coupler so that they can use a micrometer to check the size. Maybe get a couple of spares as they are cheap. /forums/images/graemlins/grin.gif
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
LOT: Assorted Liebherr Filters (A59076)
LOT: Assorted...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
(2) HOMELITE BLOWERS (A58374)
(2) HOMELITE...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
