7308 Loader problem???
   / 7308 Loader problem??? #1
Fishguy
Northeastern NC (flatland)
NH TC30 HST
Hey Everyone,
Been a while since my last post but I have run into a problem with my loader on the TC30. Not sure of the cause but let me say my daughters love to play on daddy's tractor when I'm not using it.
The other day I was hosing the tractor down after use and when I move the joy stick to the "rapid dump" position to empty it of water the bucket actually curled up! I have also noticed that the loader no longer will lift the front end off the ground. If I have the bucket tilted slightly down and lower the arms the bucket will level it's self to the ground and stop at full down.
Any suggestions?
I called the dealer and the thing is still under warrenty so fixing is not an issue. I'm justr not crazy about having to load it up and take it there and be without it for no telling how long!
Thanks,
Steve
   / 7308 Loader problem??? #2
Maybe start with checking linkage under rubber boot on joystick?Nuts ,pins, or bolts may be loose .......... Someone may have attached some hydraulic lines on junction block backwards?
   / 7308 Loader problem??? #3
Sounds like quick disconnects are improperly attached. Remove all four and reattach again in proper order.
   / 7308 Loader problem??? #4
Was curious to know how your hydraulic problem worked out.
2020 Case 5550 Trident (A56438)
2020 Case 5550...
Cushman Electric Cart (A55851)
Cushman Electric...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
Utility Cart (A59228)
