7308 weld on cutting edge
   / 7308 weld on cutting edge #1
engelb77
new holland tc33d
anyone know the thickness of the weld on cutting edge for a 7308 FEL ? Today i was looking at my cutting edge and its getting worn down. Looked online at them and a 60 inch (which is what i need) is about $30 than the 68 inch. Why? Anyway was wondering why i couldn't just buy the 68 inch and cut it down to fit or is there a reason i couldn't do this? Or could i just go to a steel shop and buy a 60 inch piece of flat bar and weld it on? would that work or would that metal be to soft? well thanks for any help or replies guys.
   / 7308 weld on cutting edge #2
You should be able to pick up or order cutting edge from steel suppliers,farm supply outlets, firms like Catapillar etc.
:D
It comes in different width/thickness/length. It is not ordinary flat bar stock but steel that is formulated to be tough and wear resitant. Cutting torch will cut it.:thumbsup:
   / 7308 weld on cutting edge #3
Today i was looking at my cutting edge and its getting worn down. Looked online at them and a 60 inch (which is what i need) is about $30 than the 68 inch. Why?.
What was the total cost? (cost of materials and labor) You might be able to buy a reversible bolt-on edge and just have your cutting edge drilled to fit. It would depend on the difference in cost. Messicks.com has a reversible bolt-on edge for $210. It's part number is 716426016. If your bucket is pre-drilled, it's an easy install with flat-head sweep bolts.
I think what you saw was a typo for the prices of the weld-on egdes. I believe they got the 60" and 68" prices reversed. As you say, it does not make sense for the 68" to be $30 cheaper.
Informational Lot - Shipping (A56438)
Informational Lot...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
golf cart (A56859)
golf cart (A56859)
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58216)
2019 LOAD TRAIL...
