755 Compact Tractor Battery is inflating like a balloon.
   / 755 Compact Tractor Battery is inflating like a balloon. #11
Pull the alternator and take it to an electrical shop that tests, repairs, and rebuilds alternators, generators, electrical motors, etc. They can test it and then repair/rebuild if needed. Run, don't walk. Also, get that bad ruined battery out of your equipment before something more major happens.
   / 755 Compact Tractor Battery is inflating like a balloon. #12
Bird the battery is an Exide 60 premium with two plastic caps on top covering the six openings. I am going to replace the battery, but how would you unclog clogged vents? I am assuming you simply pop the caps off and clean them?
If you're going to replace the battery anyway, and I certainly agree that you should, then I wouldn't mess with the old one; however, you're right; pop the caps off and clean them. You should see the vent hole in the 3 parts of each cap that fits into the battery.
   / 755 Compact Tractor Battery is inflating like a balloon. #13
very good advice, unless you are electrically inclined?? Parts are high for alternators. The self regulators are very tricky inside. I repaired the older GM 10 models..You definitely need an electrical diagram of the unit...to trouble shoot it..
   / 755 Compact Tractor Battery is inflating like a balloon. #14
There is probably a skilled small business owner in your area that will test and rebuild it. I recently lucked out when I called a couple parts shops looking for a new starter. One guy turned me on to a local service shop that rebuilt mine as good as new..... for half the price of one from a parts store.
Good. Luck
RoN
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
Utility Trailer (A52377)
Utility Trailer...
Test Button (A47477)
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
