755 leaking front knuckle
/ 755 leaking front knuckle #1
farmguy9909
Washington, NJ
Gravely 18G
Hey guys. I have a mfwd 755 that has a knuckle that is leaking severely. I think a seal is bad. Any tips or places to find info to fix it?
/ 755 leaking front knuckle #2
Shoot me your email and I'll send you a PDF of the Deere tech manual
Joe
I got everything torn apart and checked out the damage. Turns out the front right side knuckle was destroyed at some point and put together missing some parts. The needle bearing was busted, the oil wear sleeve on the axle end was gouged, and a bolt that holds the upper and lower knuckle halves together had a broken easy out in it.
I got everything ordered and cleaned up. Back together she went and all is good as gold! Glad I can start using her again! Thanks for the help!
