770 Hydraulic fluid capacity
   / 770 Hydraulic fluid capacity #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
I'm looking for the hydraulic fluid capacity for the 770.
I want to run a hydraulic motor, driven by the onboard hydraulic system, to power a front mounted snowblower, attached to the FEL, and need to figure out if an additional reservoir is necessary.
   / 770 Hydraulic fluid capacity #2
Here are the specs of the Hydraulic capacity of the 770:
working pressure 2050 psi
pump capacity (main) 5.6 gpm
pump capacity (steering) 4.3gpm
total flow of pumps 9.9 gpm
I think you'll find it hard to accomplish your task with the tractor's setup. One way, would be to run a PTO pump with it's own hydraulic system for the snowblower. There have been several threads on the subject on TBN, if you do a search you will find several other questions similar to yours.
