78 Ford 1900 - Q for RCH
   / 78 Ford 1900 - Q for RCH #1
idaho04
I am new to this group. I own Ford 1900. One problem I have is that the loader will not function if the 3pt is not in the lowest position. Browsing through some old mail I noticed this solution submitted by RCH:
<<<Fitz, I have a 1910 with a factory FEL. Look on the right side rail were the bell casting tapers into the transmission ( in front of the brake pedals) and you'll see the "Combination System Relief-Diverter Valve Manifold Assembly". It's a square block about 3-4" with 2 Allen headed plugs(these are auxillery ports and may be in use on your configuration) and between them and a little lower is a slotted bolt head. It takes a pretty hefty screw driver and you don't want to wallow out the slot . Turn this 90 degrees ( if its at 2 o'clock go to 10 o'clock or visa versa). RCH>>>
I am not sure what the remedy is, I need more details.
J & M 30' Head Cart (A50514)
J & M 30' Head...
2012 ISUZU NPR 18 FT FLATBED (A52141)
2012 ISUZU NPR 18...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
