7800 Top and Tilt
   / 7800 Top and Tilt #11
8561 said:
...A quarter inch valve (like on the 7800) is either full up or full down, until you stop it by going the other way, with one exception. You can alter the height a quarter inch at a time...
This hasn't been my experience on the B2620. How do you get it to move just 1/4 inch? What I find is that the 1/4 inch valve is really just two stop points on the 3PH lever (up and down) that results in the 3PH being raised or lowered very slowly. It makes it easier to do fine adjustments because you can just push the 3PH lever all the way up or down, and have it adjust slowly, but I don't see how it is used to adjust by 1/4".
   / 7800 Top and Tilt #12
When adjusted properly, the lever to raise, and lower the 3pt hitch is spriing loaded. It's my guess that if you move it in the direction required from the neutral position to the stop, and release it, the lever will return to the neutral position, limiting the movement at the rockshaft to about a quarter inch. It would depend on how far to the rear of the 3pt arms the implement is how much that would move. The system looks like it would work OK when using the ground level as a reference. One could lower the implement slowly until it touches the ground, and then bring it back up a certain number of "hit, and release" movements to be roughly in the same place each time. I also think it works pretty well if you are making small adjustments as you move along grading, etc. PC, on the other hand is great for returning to the same depth either above ground, or below ground every time with out requiring a reference to the ground level each time by setting the depth stop, or just retuning to the same number on the scale each time. If one is moving along wavy ground, and trying to level it by compensating the depth of the implement to the tractor movements, I expect that either works just as well. I really think that both sides are right in certain situations in this debate. QI= ground level, or eyeball for reference, PC= reference scale.
   / 7800 Top and Tilt #13
My lever does not spring back, at least not quickly (if I recall correctly, not at all). Therefore I don't use "hit and release", but I do use "hit and return" to get small adjustments. Sounds like something else to have my dealer look at when I bring it it. When he explained how the 1/4 inching valve worked, it was like you described.
   / 7800 Top and Tilt #14
I see now that it does spring back when moving the lever up, but not when moving it down. I see the spring that does this. However, there is no spring for the opposite direction, although I see no reason why one couldn't be added.
Can someone with 1/4 inching valving confirm whether or not your 3PH lever springs back to neutral after using it to lower the 3PH. If so, can you check if you have 2 springs and not just one.
Thanks!
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
