782 cub cadet
/ 782 cub cadet #1
fecret66
I recently purchased a 782 with a hole in the motor, found a used 17 hp on craigs list.Flywheel from original motor did not fit new motor. where are the serial numbers located on the motors? and where can I find a used flywheel ?
/ 782 cub cadet #2
You can find used flywheels all over the place, really. Cub Cadet is a sure place to get it, but I'm sure you could find others. As for the serial number, It is on a sticker on the flywheel shroud, no worries if no sticker is visible, the numbers are stamped into the block.
/ 782 cub cadet #3
check out the cub cadet warehouse online....they have a lot of stuff
2006 MACK CHN613 DAYCAB (A67714)
2006 MACK CHN613...
2021 Kubota M6S-111 (A64911)
2021 Kubota...
AIR OPERATED OIL PUMP APROX 200 GALLON TANK (A67714)
AIR OPERATED OIL...
2026 57in Rotary Brush Cutter Skid Steer Attachment (A66734)
2026 57in Rotary...
2012 FORD F250 EXTENDED CAB PICKUP TRUCK (A66091)
2012 FORD F250...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
