790 3PH lower arm stability
   / 790 3PH lower arm stability
Your second answer is most likely the reason I am having trouble, because I use the Disc and a Box Scraper with rippers most of the time. I don't turn with the Disc down but have to sometimes with the Box Scraper while contour grading for landscaping.
I have checked out other tractors in the 3000 and 4000 series and found that they have a superior system. Only the 700's and 900's and below use the chain stabilizers. All of the larger tractors use a fixed pin system that adjusts by dropping a pin into a hole on a steel bar that is attached to the axle. No stretching.
   / 790 3PH lower arm stability #13
I have probably 75 hours of just box blade use and have not had this problem. I only keep mine tight enough to keep it off the wheels though.......
   / 790 3PH lower arm stability #14
New/Unused Agrotk Tire Changer (A54865)
New/Unused Agrotk...
2012 PETERBILT 337 CHEMICAL TREATER TRUCK (A55745)
2012 PETERBILT 337...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
