790 What accessories do I need? Hydraulics i match
   / 790 What accessories do I need? Hydraulics i match #11
Buck, do you have a good source for the toothbar? And cost?
   / 790 What accessories do I need? Hydraulics i match #12
As Buck said, A tooth bar for the FEL is almost a must for any kind of digging. Have some hooks welded on the bucket also. The three things i use most are; 1) FEL, 2) 5' rotary cutter, 3) 6' landscape rake.
   / 790 What accessories do I need? Hydraulics i match #13
Bucket level indicator, work light, block heater if you are in a cold climate. I would get also get any plumbing you want done right away (extra SCVs, rear ports, etc).
On the imatch thing, I waited and went with Pat's Easy Change instead. I get a lot of use out of my PHD and its one of the few systems that works with that.
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
90018 (A48082)
90018 (A48082)
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
John Deere 3038E (A50123)
John Deere 3038E...
