790 What accessories do I need? Hydraulics i match
   / 790 What accessories do I need? Hydraulics i match #1
herbsclub
I am going to buy a 790 with fel 419, lx5 brush cutter, 5ft. box cutter, and maybe disc, mud tires. what else do I need?
   / 790 What accessories do I need? Hydraulics i match #2
Sounds like a fine setup. About the only things you'll actually NEED will be a diesel fuel can and some spare shear bolts for your cutter. Other things that come in handy will depend on what you are doing. Various clevis's for the drawbar are nice. Some chain for dragging things. Spare lynch pins for the tph (they always seem to walk away). A rear work light is great. Hooks on the FEL bucket are especially handy.
Again, depends on what you intend to do, but there is no shortage of "stuff" to accumulate if you want /forums/images/graemlins/smile.gif
Shear pins, rear work light, top and tilt, hooks for fel, what else, thanks
   / 790 What accessories do I need? Hydraulics i match #4
What is your intended use of the tractor?
The list, so far, pretty much includes everything you'll need initially.
   / 790 What accessories do I need? Hydraulics i match #5
You may want to think about an optima battery to replace the stock one.Mine was fine for a while but the violent shaking of it has caused some juice to jump out and corrode parts of the hold down assembly and the place where the battery sits.I cleaned it and tried to neutralize with baking soda, then dried everything and painted over the bad spots. A few weeks ago I looked under the hood before starting and it would seem that my efforts to stop the acid attack were less than perfect.To me it is going to be worth 109 dollars to stop this for good.
   / 790 What accessories do I need? Hydraulics i match #6
I'd recommend a grille gard, when the salesman told me how much, I said "for that?" I figured I would make one that was better. Long story short its cheaper than new grill parts and the grief involved.
   / 790 What accessories do I need? Hydraulics i match #7
A hydraulic top link will make the whole tractor or any tractor immensely more usable. Of course, that will depend on your use, but even a mower will benefit from a hydraulic top link. If JD is still using the acid leaking mess, I would agree, take out that battery and get soemthing else, it makes mess. You can use that battery for a power sprayer or something. Those are the two immediate things I would want.
   / 790 What accessories do I need? Hydraulics i match #9
My battery didn't leak, but the connectors kept corroding. In my case, the dealer replaced the battery and put real cables on under warranty.
Everything else has been fine. It is a real nice machine. You are going to be very happy.
Buck
2013 Freightliner Hydro Vac Truck (A53117)
2013 Freightliner...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
Caterpillar 259D (A50123)
Caterpillar 259D...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
