825i gator
/ 825i gator #1
cantbeatadeere
Bronze Member
UPSTATE new york
clearing snowmobile trail blow downs yesterday, hooked the jd winch to a tree and winched it loose, then was pulling it in reverse into the woods and needed to steer clear of a stump,soon as the wheel was turned --POP-- right c/v shaft went. Don't steer when pulling in reverse(bad things will happen)
/ 825i gator #2
been there, done that.
you are right, that is the worst possible thing to do to a cv shaft. lots of torque at bad angles.
/ 825i gator #3
If it is still under warranty, I'd call the Deere dealer to see if it is covered. Seems like it should be covered.
/ 825i gator
if its not warranty this will fall under the category of NO GOOD DEED WILL GO UNPUNISHED...work in 13 deg weather for 7 hrs for free and have to buy a 230.00 shaft to boot, don't mind paying for the gas:confused2:
/ 825i gator
dealer covered the shaft:thumbsup:, also the new shaft has a new part number. don't think they would change the num. if the shaft was the same so prob. a better/stronger part. still won't steer in reverse though:laughing:
/ 825i gator #6
John Deere is really good on tractor warranty stuff so figured there's a good chance they'd cover your broken axle. Seems like it should not have broken in the first place but it was likely defective.
