My 1100# bushhog 306 was 42% of the weight of my
L3400......and I liked it very much.
My Woods DS96 @1620# is 43% the weight of my MX5100.......I also like it very much.
The
L3560 isnt much smaller at all. Only ~200-250#. And actually (according to ratings), has a stronger 3PH. Sure, may need a little additional front weight since the 3560 is lighter....and my woods DS96 does make me light and I'm a tad heavier.....but I wouldnt have a moments hesitation hooking a DS96 to a 3560.....especially if HST. 8' cutter at 2 MPH cuts just as fast as a 4' cutter @ 4 mph. (actually a tad quicker cause less inefficiency and turns, but I wont go into that). But a 2MPH ride is much more pleasant, smoother, and easier on the tractor.
To tell someone to stick to a lighter 6' cutter for that HEAVY 35HP tractor.....as some have done in this thread.......is a silly proposition IMO. That think will run a heavy 6' all day long. As well as a reasonable 7' cutter.
HP dont need to dictate the size of the mower. That should be left to tractor weight and hydraulics. HP only dictates how fast you can mow....in terms of acres/hour. A larger cutter is NOT going to be slower. Ground speed slower....yes. Overall mowing time slower.....just the opposite.
I much prefer to mow slow and wide......as opposed to fast and narrow. If you choose the opposite using a 81HP tractor and 7' cutter, more power to you.
Sure, there are several valid reasons to choose a smaller cutter. Affordability, gates, trails, trailing, maneuverability, dont have alot to mow and dont care about inefficiency, only ever cutting nasty 10' tall overgrowth (briers, saplings, etc), availability, etc. But HP shouldn't be a large determining factor, especially on a HST tractor. If you are cutting pastures, grass, open areas......the most efficient (fastest) way to cut is to get the biggest the tractor can physically handle.
I have 42 PTO HP on my MX. I am currently keeping an eye out for a lighter 10' twin cutter. Something in the 1500# range. I cut alot of pastures and open areas that some get cut as often as once a month. Power is a plenty with 8' cutter. What slows me down is terrain (bumps), and simply overrunning the cutter. (Driving faster than the blades can actually make a revolution without skipping uncut grass). Many many times I am mowing at 7-8 MPH and wishing I had a wider cutter. Not once have I ever wished for smaller. I can always slow down.....or take smaller bites with a large cutter. But you can NEVER take a larger bite with a smaller cutter....or mow faster than the tip speed will allow without overrunning.
the OP can buy whatever he wants and make his own decision. I am by no means trying to say he should go buy an 8'+ cutter. A 6' cutter would work perfectly. All I am saying is dont pass up a good opportunity to buy a HEAVY 6' cutter.....or even a medium 7' cutter just because someone on the internet thinks it needs 80+ HP to run.
