8400 low hydraulic pressure
   / 8400 low hydraulic pressure #1
Ag Tech740
Somerset, Ky
8400JD
I have an 8400 JD that is only putting out 1800 psi hydraulic pressure. The specs call for 2900 psi. The pump has been replaced with a reman pump. Can the pump pressure be adjusted and if so how is this done? I will be checking pressure and flow at the remotes. What other problems could be affecting low pressure? Thanks!!
   / 8400 low hydraulic pressure #2
:welcome: to TBN
Hope someone here can get involved in your problem.. sorry I cannot help.
   / 8400 low hydraulic pressure #3
I suppose the hitch relief valve could be faulty. I see what I think is shims but they appear to only be available in a kit that's too expensive to experiment with.
key 7 RE39396 Pressure Relief Valve - ADD 310.36 USD
   / 8400 low hydraulic pressure #4
There are 2 different pumps that can be on your tractor. Do you know if the pump is 57cc or 45cc? The adjustments are different on each one.
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
JOHN DEERE 24" PIN ON EXCAVATOR BUCKET (A52707)
JOHN DEERE 24" PIN...
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
2021 BOBCAT T740 SKID STEER (A52706)
2021 BOBCAT T740...
