DavesTractor
Elite Member
I know this should go without saying, but do make sure if you are doing the "slam the brakes" trick that the clutch pedal is also all the way to the floor when you do it.
We had an older but very low hour and very clean Kubota in the shop recently for a stuck clutch. We bumped it a few times and it was really stuck. We split it and were glad we did. The flywheel was deeply rusted and pitted. 135 hours if I recall correctly and the tractor was clean as a pin. Not sure how it go so very stuck. We have a dry climate, so we only see this a time or two a year. That and the fact that most folks do not park there tractor for months on end. Frequent use generally keeps this from happening.
Good luck, I hope you get it.
