870 wont start, no power at dash
   / 870 wont start, no power at dash #11
check the large 60 amp fuse located next to the starter...if i remember correctly. this is a main fuse
   / 870 wont start, no power at dash #12
Try putting your positive voltmeter lead on the large cable connection on the starter and the negative on the frame. Turn on the switch and see if voltage goes away there also. If it does, you have a bad cable or connection. Then try touching negative lead to battery post. If voltage stays good, then the negative cable is bad or cable connection to frame is bad. If voltage still drops, then the positive cable is bad. .
   / 870 wont start, no power at dash #13
See if the seat switch is blocked. Also push the seat forward and pull up the safety switch to allow you to start it without being on the tractor.
   / 870 wont start, no power at dash #14
Bad ground. Have redone ground twice on mine
2015 CATERPILLAR 259D SKID STEER (A52708)
2015 CATERPILLAR...
11L-15 TIRE W/ 6 LUG ALUMINUM RIM (A52708)
11L-15 TIRE W/ 6...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
2019 SPM 2500HP QUINTUPLEX FRAC PUMP (A58214)
2019 SPM 2500HP...
2017 Ford Transit 250 Cargo Van with Lift (A56858)
2017 Ford Transit...
SHOPBUILT T/A METAL TRAILER (A52708)
SHOPBUILT T/A...
