885xl pto input shaft
   / 885xl pto input shaft #1
retro7570
floyd,va.
4040 john deere
pto input shaft splines are shot where it splines into pressure plate. split tractor, removed throwout bearing and 3 bolt cover but shaft will not move, attached gear puller, slide hammer, still no movement. ideas please, thanks in advance
   / 885xl pto input shaft #2
So the solled shaft stay in the pressure plate ?
Loosen the pressureplate and remove all.
   / 885xl pto input shaft #3
Is this a Case IH 885 or a David Brown Case 885?
Whatever version, the PTO shaft may come out the back of the tractor and it is being held by a bearing from coming out the front.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LEE BOY 8520B ASPHALT PAVER (A60429)
LEE BOY 8520B...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Honda UTV (A56859)
Honda UTV (A56859)
