8N Sputters...New Plugs??
   / 8N Sputters...New Plugs??
"fire order is 1-2-4-3 if you get messed up."
I admit I don't know much, if anything, about firing order. I assume it is correct now or it wouldn't run?? I should be able to match the existing setup. When you say 1-2-4-3, where does the 1 start?
   / 8N Sputters...New Plugs?? #12
1 is at the radiator. Also.. these 4 cyl N engines will start on 2 cyls.. and will run reasonably well on 3 cyls. Howebver.. if ya had a wire swapped.. you'd have 2 cyls at max.. and that probably would stall trying to let the clutch out.
Soundguy
9202 (A50322)
9202 (A50322)
2003 John Deere 310SG (A47477)
2003 John Deere...
City of Lakeland (A51691)
City of Lakeland...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
Heritage HC72 Rotary cutter (A53473)
Heritage HC72...
