8N STEERING QUESTION
   / 8N STEERING QUESTION #1
rzacc
Greetings all. My 8n steerig is very tight and hard to turn. Does anyone have any suggestions?? I tried to loosten the adjusters, but the inner screw only turns about 1/2 turn. Im not sure if I should push it, or not, or if it will do anything anyway. Thanks in advance.
Ron Z
   / 8N STEERING QUESTION #3
I'm assuming you have the late steeing box with sector adjust studs.
did you loosen the locknuts before you tried to turn the studs?
in any event.. if it is already tight. adjusting the studs off will just add backlash.. I'm not sure that's what you want.
jack the front up and see if there is any rise inthe steeirng wheel when you turn... also does it turn freely up? many times spindle bushings will wear and cause hard steeing.
if the thrust bearings are gone and someone honked down on the sector adjusters that will do it to.
post back.
soundguy
1605 (A57192)
1605 (A57192)
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2016 LEEBOY 8510D ASPHALT PAVER (A60429)
2016 LEEBOY 8510D...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
