94 Ford/Newholland 1215 Drive shaft leaking very bad at rear case
   / 94 Ford/Newholland 1215 Drive shaft leaking very bad at rear case #1
topfli8979
Springfield,Missouri
Ford 1215
I picked up a 94 Ford 1215, runs great, but spews tractor fluid out around the drive shaft at the rear. I took a look and it appears the oil seal is completely missing.... I can see the bearing. What is the process of replacing this, do I have to split the tractor to replace oil seal?
Is there supposed to be a oil seal covering the bearing?
   / 94 Ford/Newholland 1215 Drive shaft leaking very bad at rear case #3
yes there is a seal missing, a call to the dealer will answer your question on how to replace
