95 F350 power steering pump issue
   / 95 F350 power steering pump issue #1
Newblue
Central Indiana
New Holland TC45DA SS
95 F350 2WD, 460 motor. When the engine is off and the steering wheel is turned, the fluid in the reservoir will pop the cap off and spray fluid under the hood. It works perfect when the engine is running and the steering wheel is turned. With the front jacked up I can grab the rotors and run it lock to lock and no fluid will come out. This has me puzzled.
   / 95 F350 power steering pump issue #2
Has to be a stuck check valve or pressure relief valve.
How much is a new pump?
Chris
   / 95 F350 power steering pump issue #3
Had a similar problem on at least one of my old 88-91 F250/350 trucks. Replaced the cap and it solved the problem (although as Chris suggests it may be more involved than that)
The caps have little plastic locking lugs that flex and weaken over time.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
