950, 5ft bushhog overheating
   / 950, 5ft bushhog overheating #21
Well the fan pulls air really good its not that. Plenty of air coming across the radiator. But first thigs first am i asking to much of the tractor or should it be able to handle that work?
It should handle that task
   / 950, 5ft bushhog overheating #22
1) Bad fan clutch
2) Worn pump impellers
3) Bad stat
4) Dirty radiator
5) Bad injectors
6) Bad fuel pump
   / 950, 5ft bushhog overheating #23
I agree that it should have plenty of power. You should not be able to overheat it unless it is constantly noticibly bogging down. I have more power, but I run a 6 footer and the temp never rises above normal except when I am mowing something with a lot of seeds that keep clogging up the screen. My tractor will bog down in the thick stuff long before overheating is an issue. You may have less power than the bigger brothers in that family but you also probably have the same radiator so there is less of a heat load on it.
As mentioned already, flush the system... your cooling system is not running at peak efficiency. Only other thing to check is maybe air filters and possibly exhaust blockage.
   / 950, 5ft bushhog overheating #24
If you eliminate all other possible causes first I have seen instances where the impellers on the water-pump disintegrate without the pump assemble leaking thus the pump cannot pump the appropriate volume of coolant. This is rare overall but possible especially if the unit is older and the water pump has been in service for an extended period of time. Usually when water pumps fail they leak but not always. If everything else has been ruled out maybe time for a new pump. Goodluck
   / 950, 5ft bushhog overheating #25
Rock Knocker's list is spot on IMO!!! Make sure to throughly check the radiator as well and don't hesitate to take it to a radiator shop. Make sure yousolve this problem before you blow a head gasket!!!!
   / 950, 5ft bushhog overheating #26
The fan belt and fan/waterpump pulley may appear ok and tight. Odds are the belt is glazed and is worn out of ture.If worn, no amount of tightening will make it drive withut slipping and bearing life will be measured in dozens instead of thousands of hours.
If you pull the sheet metal and fuel tank off. Odds are you will find a rad you thought was clean. is actually plugged with oily mud. Bent fins from somebody using a HP washer doesn't make cooling better either.
If there is any oil contamination in the coolant. The oil makes a slimy insulating film and foam that reduces cooling.
Coolant needs to be 50/50 HD diesel coolant and distilled water. Tap water does contain minerals even if it's been through a water softener. Even a thin film of minerals barely eough to see is an insulator.
What is the air temperature in the shade?
How do you know the engine is running hot? Boiling over over? Is the gauge between normal and hot, that is no problem? Is the gauge buried in the red? Failed gauges in machines of that vintage is very commom. Dunk that sending unit in water on an active rolling boil and find out the actual indicated reading.
210F is not really that how for a modern working diesel engine. It is a pressurized cooling system with a 50/50 mix.
Is the rad cap any good and holding 15psi?
Repair the brakes. It worries me that what else did some slob ignore when he ran it without brakes for how many years before you purchased the tractor?
Brakes (950/1050)
Cart key PART NO. PART NAME QTY SERIAL NO. 850 950 1050 REMARKS
1 CH11253 Tube 2 X X
2 CH11255 Lever 1 X
CH13128 Lever 1 X (NLA)
3 CH11251 Housing 1 X
CH13126 Housing 1 X
4 CH11252 Gasket 2 X X
5 CH11249 Brake Drum 2 X NLA
CH13124 Brake Drum 2 X
6 CH11247 Brake Shoe 4 X
CH13123 Brake Shoe 4 X
7 CH11248 Spring 4 X X
8 CH11256 Shaft 2 X
CH13129 Shaft 2 X (NLA)
9 CH11250 Housing 1 X (NLA)
CH13125 Housing 1 X (NLA)
10 12M7066 Lock Washer 8 X X 10 mm
11 19M7167 Cap Screw 8 X M10 X 25
19M7550 Cap Screw 8 X M10 X 35 (HS=10.9)
12 CH11565 Packing 2 X X
13 CH11257 Washer 4 X X M10
14 19M7167 Cap Screw 4 X M10 X 25
19M7550 Cap Screw 4 X M10 X 35 (HS=10.9)
15 CH11254 Lever 1 X
CH13127 Lever 1 X
16 14M7276 Nut 2 X X M16
17 12M7069 Lock Washer 2 X X 16 mm
18 24M7053 Washer 2 X X 17 X 30 X 3 mm
I was a able to adjust the brakes with the nuts on the linkages and they are working now. The pedals just where out of adjustment.
So using my little thermometer next time im mowing heavy stuff what temp is considered danger zone? And where should i measure on the top of the block?
I have no signs of overheating whatsover except the idiot light. The tractor runs nice and smooth and only "bogs" a tiny bit when i make my turn and start on the hill but it catches up under a second just blows out a bit of smoke and slow a bit
Ambient today was 95* but ive had it doing it in the 70* early this year
   / 950, 5ft bushhog overheating #29
Time to dunk the idiot light sender switch connected to an ohm meter in a pot of constantly stirred water on the stove. Stir with a candy thermometer.
220F is time to get concerned but don't panic until 230F.
   / 950, 5ft bushhog overheating #30
Just because it hasn't been mentioned...did the previous owner use anti-freeze?
MarkV
2015 CRESCENT  MANIFOLD TRAILER (A53843)
2015 CRESCENT...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
25 - BINDERS (A53843)
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
