Mechanos
Veteran Member
Ran into a couple of problems when I fired up my 955 project tractor tonight after swapping in a different transmission:
Not really sure where to start looking into these problems and looking for a little "been there" advice.
Thanks.
EDIT: Ok, I'm feeling a little dumb at the moment. Went back out to the barn for a fresh look. The rate-of-drop valve was too far closed. Opened it all the way and I can easily push the lift arms down. Disregard the rockshaft issue above.
- PTOs won't engage. With the PTO magnet manually bypassed (seat switch not installed yet) neither of the PTOs will engage when the PTO lever is engaged.
- Rockshaft will not lower. When I cycled the rockshaft lever, the lift arms will raise, but when the lever is moved into the "down" position, the lift arms will not lower.... even with me standing on them. I thought this might not be enough force so I even tried putting a little pressure on them lift arms with a come-along. No dice... the lift arms will not lower.
Thanks.
