990 tractors-can they be used for haying?
   / 990 tractors-can they be used for haying? #11
When I was a kid, my father used to pull a two horse trailer behind a 1965 VW beetle. Mostly as a utility trailer, hauling hay and sawdust. Could it be done?, absolutely. Was it the right thnig to do? I'd have to say definately not.
   / 990 tractors-can they be used for haying? #12
Well put Bill. There's a reason farming has so many accidents and it isn't because people do everything right. We have a big family and knock on wood nobody has ever been seriously hurt in my lifetime. I firmly believe one of those reasons is because of the safety that my grandfather instilled in everyone. I have made a couple of really stupid mistakes that were because I did things like using too little tractor for too big a job. Like you said you can do alot of things but it doesn't mean it's right or safe.
   / 990 tractors-can they be used for haying? #13
Another option would be a older baler with a pony motor. It wouldnt stress the tractor and a small square baler wouldnt be to much of a problem to handle. Even if it cant run the baler, it can run the sickle bar, the tedder, and the rake with ease. Then your buddies who hay can just come in an roll it up if you are ready.
The other part of the thing is with all of this rain, there will be a LOT of junk hay for contractors.
Hog it off, its probably not worth the time to make it into bales.
   / 990 tractors-can they be used for haying? #14
I saw this thread and I just have to laugh. I find it very interesting that 35 hp is too small when there were a whole lot of balers made when the biggest tractors were Farmall Ms or Oliver 88s and these 35 hp tractors were out in every field in the nation baling hale. Now we think of a 4020 as a utility tractor. Of course they can be used safely for various haying operations - they did it for years. You just cannot be stupid about it like trying to make it pull an 18' wagon behind the baler almost full of alfalfa bales while also trying to power the baler.
   / 990 tractors-can they be used for haying? #15
Well I believe the 990 (kind of an economy version) and even more so the JD 1070 (more a deluxe version) were some of the the biggest heaviest "classified as compact" tractors to ever be offered. The 1070 even had draft control for the 3 point hitch for plowing. Might be the only compact tractor that I have ever seen draft control feature offered on as most compacts only have position control and some of the real cheapies even that position control does not work all that great. There was a time that I really wanted to own a JD 1070 (just too expensive for my needs back when they were new - might be more affordable now as used).
Anyway, You easily have enough hp if you pick the right small square baler. Doing just a few acres the tractor will likely hold up fine. Start covering many acres though and the the PTO driveline strength will likely come into play in a typical lightweight compact even if it has the hp. A 990 or 1070 being a little larger and heavier than the typical compact then it might have a little more strength in the PTO driveline (not sure). Regardless, there is a reason that I think almost every manufacturer has a "voids the warranty clause" on their compact tractors if you hook it to a baler. I am sure their testing likely shows failure problems. A baler is a herky jerky type load on the PTO. No problem on bigger tractors with lots of steel to absorb that herky jerky action even if they are low hp.
So the catch 22 is you are likely fine on just a few acres, but doing hay on only a few acres is rarely profitable or worthwhile (from a cost/benefit perspective). Try to cover a lot of acres with a compact tractor to make doing hay more feasible, justifiable, and profitable then your lightweight tractor will likely not hold up.
I have hobby hayed for quite a few years with a lightweight Kubota L285 (pics on this sight even). It actually handles the baler pretty darn good and the Kubota's choice of slow gear speeds is wonderful. Would I do 25 acres with it? No way as I really like the little tractor and want to keep it nice. The baler now goes on a clunker Farmall h or Farmall M. Nearly a Zero chance the baler will hurt either of those old heavy clunker Farmall's. The Farmall h even has less hp than the Kubota but it does have more torque, mass, and PTO driveline strength.
International 133 6 Row Cultivator (A50514)
International 133...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2008 Ford F-250 (A52128)
2008 Ford F-250...
