A couple 4300 questions.
   / A couple 4300 questions. #11
A little addition here:
The R-1 Ag and R-4 Industrial tires are not reversible. These tires are unidirectional for traction. There will be an arrow embossed on the tires' sidewalls to indicate the correct direction for mounting.
So, R-1's and R-4's are actually swapped side to side.
R-3 Turfs are reversible.
If those tires aren't filled with liquid ballast, I suggest you do so. That really helps with stability!!
BTW, I have a 4400...same machine as yours with a bit more horsepower.
   / A couple 4300 questions. #12
Deere recommends only one position for the front wheels when using
R1 or R4 tires. You don't really gain any stability in the front anyway,
since the axle pivots in the center.
They DO say it is OK to run these tires backwards in the front only
to assist in backing up when doing lots of loader work.
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
1989 TRAILMOBILE 45X96 SPREAD AXLE FLATBED TRAILER (A53843)
1989 TRAILMOBILE...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2018 CHEVROLET SONIC (A53843)
2018 CHEVROLET...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
