JDTank
Platinum Member
- Joined
- Oct 5, 2010
- Messages
- 693
First of all the reason most of these mowers use the electrical clutch setup is to be able to use the safety interlock switches. The safety constraints have to be met by all manufacturers and is easily done with switches such as the RIO for backing up, operator presence, starting with mower disengaged. So more than anything it is a liability issue for all makers.
This same pto switch is used in most of Deere's equipment and I have read nothing about these being problematic. All four of my newer tractors use this switch. I changed out the switch in my L130 when I changed the clutch but it was still working. Haven't had any problems with any of them so far.
Hydraulic power is provided by the Tuff Torq hydrostatic axle on all models that offer power steering and power lift. Starting with the K58 tranny an (H) suffix designates the optional hydraulic function. So a K58H is what is used in the new x310 model. In the x749 the larger K92H is used which provides the necessary hydraulics for the entire machine.
In all cases for the newer equipment the power deck lift utilizes a small hydraulic cylinder powered by the hydro axle assembly. I haven't had any problems with any of this so far including the 3ph, used it extensively on the x749 today clearing away about 18 inches of snow.
About the choice of mechanical deck lift vs hydraulic, I have the simple mechanical lift on my L130 works great imo. If you are considering a larger heavier deck, snowblower or 3ph you will want the hydraulics.
As I mentioned in other threads the L130 is all I really need to mow my own lawn, the x749 comes into use for other uses where my tractors can't fit or don't wan't them to track up.
jenkinsph - What is your opinion on the X540?
