A few questions on a Deere MX8 rotary mower
   / A few questions on a Deere MX8 rotary mower #1
GreenTime
North Dakota
JD 110TLB, JD 3720, JD Z997, Kubota L5740
I am considering the purchase of a used Deere MX8 rotary mower (8' wide with 2 spindles). I plan to use it on my JD 1969 2520 (61 PTO HP). I have read on some forums that users have had drive shaft problems on these mowers. Does anyone know if Deere has solved this problem and if so in what model year? Also, this mower is available as a true 3pt mount or 2 pt mount with a rear lift cylinder. Any pros and cons on the mount type or other general comments on this mower? Thanks.
   / A few questions on a Deere MX8 rotary mower #2
I prefer the semi-integral mount as the tractor doesn't have to support all the weight of the mower plus I think the mower will follow the contour of the ground better.
   / A few questions on a Deere MX8 rotary mower #3
I was recently shopping for a cutter. I ran across some posts talking about driveline problems with that cutter. I didn't see that often enough to be concerned about it. I can't answer your question about a manufacturer fix in later models.
I ended up buying a JD1008 cutter. It's considerably older than the MX models. A dual spindle cutter has one issue that can cause catastrophic failure if it's not monitored. the blades are timed because they overlap in the center. If out of time, they will hit each other in the middle and more than likely cause gearbox shaft failure. All dual spindle cutters have a driveline assembly that keeps them in time. Some manufacturers have had problems with that system failing and letting the blades hit. Don't want to get into a brand war so won't mention what I found to be the worst at having this happen, but it wasn't the MX models.
I bought a fully mounted cutter because I do a lot of cutting in woods and deadend waterways where I need to totally pick the cutter up and/or back into an area to cut. I would estimate the MX8 to weigh around 1500lbs. You may need front weights if you carry it. I had to add 650lbs of front suitcase weights on my 7500lb tractor to carry my 2000lb cutter.
If you are cutting in open areas I agree with Jim, I'd go for semi-mount. That design requires a rear remote to run the hydraulics on the rear wheels.
An ideal situation to me would be fully mounted with hydraulic operated rear wheels. Gives you the ability to change cutting height on the move.
   / A few questions on a Deere MX8 rotary mower #4
I see you can get hydraulic offset too on the semi mounted. On both the MX8 & MX10. MX6s have gear box problems. Not sure if the bigger ones do or not.
   / A few questions on a Deere MX8 rotary mower #5
Jim summed it up good - 2^x here.
AKfish
   / A few questions on a Deere MX8 rotary mower #6
Another trick to make a mounted follow contoured land better is to use a hydraulic toplink. Extend the top link and the mounted cutter then acts like a semi-mounted cutter. If you want to pick it up, simply retract the top link.
   / A few questions on a Deere MX8 rotary mower #7
My dad always used a chain instead of a toplink on his rotary cutters. He would make a chain with larger links on each end to fit the standard toplink pins. It would be long enough that with the three point completely raised it would just pick up the tail wheel. To transport it, or if he needed more lift, he just shortened the chain.
To make the same thing work with a quick hitch, he took out the solid arms that went from the mower deck to where the top link normally attaches. In place of those arms is where he would put the chains. Same result either way.
He also did this with three point grooming mowers. Seemed like it always worked well for us.
   / A few questions on a Deere MX8 rotary mower #8
Don't do it!
I've had my MX8 midi mount with side shift for 14 months and just broke the stump jumper off.
They want $3400 to repair it. I've still got 46 months left on the warranty.
Doesn't sound like they want to honor it to me.
   / A few questions on a Deere MX8 rotary mower #9
I am dealing with the same problem with my MX8, Are you interested in selling the second gearbox or purchasing mine??
   / A few questions on a Deere MX8 rotary mower #10
Oh bummer.... Two posters on the same thread with gearbox problems on an MX8....... That's not good...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2017 UTILITY VS2RA...
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
