Trev
Platinum Member
- Joined
- May 24, 2002
- Messages
- 918
- Location
- Williamson, NY (near Rochester)
- Tractor
- Currently tractor-less
I had the dealer pick up my JD4300 the other day for routine maint.. it had about 300 hours, but most of those were from running the generator during the ice storm.
I had done routine maint, but wanted a pro to check it over and make sure I wasn't missing something critical.
When it comes back, float mode of the front blade no longer works. Dealer says maybe needs breaking in. I try it a few more hours.. no joy. I also notice that the valve next to the diff lock, for selecting recirc mode for FEL, is now GONE. Completely missing. Now they say they'll have to pick it up again and see what's wrong with the spool valve and if the mechanic simply forgot to replace the lever for the recirc function. Reasonable mistake?
I also had them return the tractor with a box blade on it.. lots of land leveling to do. I found this isn't as easy as it would appear! What I started with was a garden in the back with a small depression in it.. which caused water build-up and a mess in the Spring.
What I think I've managed to create now is a much bigger lake! I dragged dirt in from the sides to fill the depression... resluting in, basically, a much larger depression (not to mention my OWN depression.) /forums/images/graemlins/frown.gif
I think I need dirt brought in. And I don't know what the heck I'm doing with the box blade.. I end up with mounds of dirt where I dump it.. and low spots where I scrape it. I've tried dumping slowly, leaving the box up part way, and so on. Is this why contractors make money.. because they actually know what they're doing?? /forums/images/graemlins/smile.gif
I had my fun.. now it's probably time to bring in a pro to fix the mess I made. Okay, it isn't really a mess... but now I have what will probably be a large lake rather than a small one. Spring will tell. I tried all angles of top link adjustment, depth of teeth, and so on. My last try will be to get my wife out there to help.. she can watch from the side and signal me to raise or lower the blade. Humiliating, I know... but you do what you have to do!
On the bright side, the JD dealer says he'll make his mistake right for me.. including free rental, delivery, etc., of the box blade in exchange for their mess-up on the SCV thing.
Hey, I dunno what I'm doing, but I'm (mostly!) having fun! /forums/images/graemlins/smile.gif
Best...............Bob
