A good budget priced welder?
   / A good budget priced welder? #31
Ive had my ac/dc tombstone for around 30 years. Bought it new. I couldnt tell you where it was made or if its better than the same machine being made now. I do know a new one is less than $500 and if it holds up as well as my old one. I wouldnt hesitate to buy it again. I see them all the time on CL for $200-250, sometimes more, hardly ever less. The old ac only tombstones bring about the same price, maybe a little cheaper and are around $200 new. Maybe a tad more. For a stick machine for hobby use hard machines to beat in my opinions. If you want mig for under $500, start looking for used machines on CL. I have seen 200amp millers and lincolns in that price range, but newer machines carry higher prices. I gave $500 for my miller 175 new in the box with cart. It was a closeout. Patience and a little searching seems to be what the OP needs more than anything if he wants to stay in his price range.
   / A good budget priced welder? #32
This reminds me when I wanted one of those tombstones, I am just glad that I got the Everlast PowerARC 300. (Thanks to everyone that helped me out on that)
like somebody mentioned early why would you pay 700+ for 150 @ 20% duty cycle, could this thing last longer than the Everlast? who knows. Would somebody keep this for ten years??
I honestly think that the Everlast is a really good machine, I cannot compare this to anything because this is the only welder that I have use. it I have burn 1/8 E7018 @ 65Amps with no problems.
   / A good budget priced welder? #34
As a noob (@ welding, I mean), can one of you more learned types give us a relatively simple explanation of the differences (in terms of how they affect use) between inverter and transformer welding units?
What I mean is not so much an electronics lesson as a practical understanding of them.
For instance, on the welding web link I followed from this thread, someone said that inverter welders have a limited duty lifetime and will eventually but inevitably stop working, vs. the Lincoln buzz boxes that will run until the pococlypse and then some....
Thanks,
Thomas
   / A good budget priced welder? #35
I wish I had a dollar for every different welder I've used over the years. Some days may be on 4 or 5 different machines, or on the same machine for months at a time.
The majority of the members here could care less about the quality of arc. Just want a machines that welds, and last for ever, for what little use it will get. A few of us here can appreciate a good quality arc. But that still boils down to personal opinion! What impresses me the most about these inverters is the control over the arc / puddle! My first introduction to any type of control other than volts and amps was in 1983 with a Linde Mig machine. First time I ever used a machine with inductance control. I had to run the procedure test for a project at the Boeing Space Center. We sheeted an 80' x 80' x 70-feet tall building with 4' x 8-feet sheets of 10-GA. All 4-walls, ceiling, and floor were sheeted. I was in the rigging crew until all the sheets were in place then I went into the welding crew. Once everything was welded up, I got stuck doing all the repairs for about 3-months. Testing crew would work nights, I'd come in the next morning grind out the bad welds, and re-weld. Every sheet was placed with 1/16-inch gap, for 100 % penetration. I plug welded the sheets to the structural steel of the building. Then the welding crew made the 100 % penetration welds. All vertical welding was done uphill. We used .030-inch wire. That job started out fun doing all the rigging, the welding got old really fast!:rolleyes: But being the only weldor in the repair crew was no fun at all!:thumbdown:
   / A good budget priced welder? #36
Thanks,
Thomas
Well, I'm certainly not a "learned type" in the welding area but here is my understanding:
Inverter welders are more electronically dependent. Lots of wiring, printed circuit boards, diodes, resistors, capacitors, relays, etc., etc. As with any electronic based device (think computers) the failure of a single one of those thousands of components will shut the process down. However, inverter welders are lightweight, energy efficient, and have decent duty cycles - depending on brand.
Transformer welders have only a few electronic parts and are thus more reliable. They have components that are heavy (wire windings), and are less expensive to make. Their reliability is due to the minimal use of items that could fail. Wire windings rarely fail.
Members like Shield Arc are really the learned ones so take this explanation for what it is worth. Hope he chimes in on this one. C'mon Shield, have that cup of coffee and get typing. :thumbsup:
   / A good budget priced welder? #37
Oh you give me too much credit! I don't know how welders work:eek:. I barely know how to use them! I just know what I like in a welder.;)
   / A good budget priced welder? #38
Inverter welders are more electronically dependent. Lots of wiring diodes, resistors, capacitors, relays, etc., etc. As with any electronic based device (think computers) the failure of a single one of those thousands of components will shut the process down. However, inverter welders are lightweight, energy efficient, and have decent duty cycles - depending on brand.
A good explanation. Here is another. An old ITT rotary dial phone (500 series) was state of the art in 1950, and has a minimum of parts to break, it is very durable, and works as well today as it did in 1950, and is all the phone anyone could ever want, right? Well apparently not. New phones were constantly developed, with more features, and more complexity. The rotary dial phone cannot begin to compare to my Motorola Droid Razr M. They still make tombstones and thunderbolts, and they are 1930's technology. They also make Inverter welders with better features, better ratings, and 1/5 the weight for a given output. But they are full of electronics, and common sense will tell you there is more to fail inside the box. So why don't you want a rotary dial phone? What is the matter with you? Why would anyone choose one of these new fangled inverter things, likely made offshore? When the tried and true," rotary dial phone" that weighs enough to give you a hernia is all you should want. I have one by the way, and I put it on a wheeled cart so it can be moved. So that is my comparison, and I believe it to be valid. If you want the old tried and true technology, by all means put your money there, if you want something more modern, put your money there.
James K0UA
Oh. if you want a boat-anchor welder on a cart, with extra long leads, mine is for sale.. $150.
   / A good budget priced welder? #39
As a noob (@ welding, I mean), can one of you more learned types give us a relatively simple explanation of the differences (in terms of how they affect use) between inverter and transformer welding units? What I mean is not so much an electronics lesson as a practical understanding of them.
Here's my take.
A transformer welder is just that: a transformer. It's two big coils of wire that converts 50 amp 240v coming out of your wall into 180-amps at 30 volts or thereabouts. If you have an AC/DC transformer welder, then it also has some diodes in it that "rectify" the AC to DC. And that is pretty much it. Add an on/off switch and a movable tap to control the output, and another big coil of wire called a "choke" to smooth the output, and you have the welder. Basically, it's just a big hose that takes the output from your wall and shoots it out the welding leads. Now, there are some transformer welders that implement more sophisticated features, but that's almost never what people are talking about when they're talking about budget welders. Open up a "tombstone" or "buzzbox" welder, and you will find: on/off switch, taps for output control, big honking transformer, rectifier array (diodes), and one or two other small odds and ends.
An inverter welders uses transistors to control the output at the leads. A transistor is like a tiny electronic switch that can turn electricity on and off very, very quickly (like, thousands of times per second). What this means is that an inverter can shape the electronic wave-form at the leads much, much more precisely and in much more sophisticated ways than a transformer can. A transformer is basically beholden to what comes out of the wall; an inverter can make the electricity sit up and do tricks! For example, the rectifier array used in transformer welders is supposed to turn the sine-wave of the AC that comes out of your wall into a perfect, flat DC signal, but in reality, there is some "ripple" of the AC waveform that sneaks through. As a result, your arc has some "wavering" in its output, getting slightly stronger and weaker just by its very nature. With an inverter welder, this isn't present, and the output of the welder is very, very close to true DC. This means that you get a very stable and controllable arc.
The real place where inverter welders shine is in their ability to manipulate heat output in real-time as you weld. Two features that are common are "hot start" and "arc force" (also known as "dig"). With hot start, the welder increases heat output by some percent for a second or two just after you start the arc. The issue here is that it takes more heat to establish the puddle, and the rod is more likely to stick when it is cold. This is a problem that experienced operators can overcome with practice, but even experienced operators can get into trouble in tricky situations, like an open root weld with a deep bevel, for example. Hot start helps prevent rod sticking and helps get the puddle established quickly so you can get to welding.
Arc force is a little harder to explain. When you're stick welding, the shorter your arc, the lower the heat input, and vice versa. This means that if you shorten the arc too much, it goes out and the rod sticks. With arc force, the welder detects that the arc is getting shorter, and when it gets beyond a certain threshold, the welder kicks up the output to compensate, preventing sticking. Arc force is usually sold as a way of preventing the rod from sticking when you short-arc, but really, it totally changes the way you run the rod, especially rods like 6010/6011, which are run with a "whip and pause" motion that relies on changing the arc length intentionally. One reason the SA-200 is so revered among pipeliners is that its volt/amps curve allows the welder to increase or decrease heat output over a significant range (like, maybe +/- 20 amps) by increasing or decreasing arc length. This meant that the welders could weld all the way around the pipe (flat, downhill, overhead) without ever bothering to move the output dial on the welder. Until inverters came along, plugs-into-the-wall welders didn't really have the ability to emulate this behavior, but now they do.
It should be said that, especially for beginners, having heat output change +/- 20 amps when you change arc length, is actually a bad thing. Beginners aren't steady enough to hold their arc length consistent, so they would be all over the place, much like a person would be if you stuck them in a high-end Ferarri and then turned off all the electronic stability and traction control. But the cool thing about inverter welders is that the designers can basically make them behave exactly how they want. Want a welder that puts out an output similar to an SA-200, and sell it to pipeliners? Can do. Most mass-market inverter welders keep a relatively steady heat output over a range of arc lengths, unless you really short-arc, in which case they crank up the output to keep the rod from sticking--and the more experienced user can do this intentionally to manipulate the puddle.
Although we're talking about stick and not TIG, it must be said that inverter welders have really revolutionized AC TIG. Before inverters, AC TIG was always done at 60 Hz, because that was what came out of the wall. Now, we can have pretty much any frequency we want, which changes the shape of the arc cone. Also, TIG welders now have pulse features that very advanced operators can take advantage of.
The flip-side of all this, some will argue, is reduced reliability. There are gob-loads of tombstone buzzboxes that were made in the 60's still welding today. As long as you don't exceed the duty cycle and burn it up, there really is not much to go wrong on them. Maybe replace the power switch every 25 years or so. But like James said, you're probably not using a rotary dial telephone, are you? And, frankly, we shouldn't assume that these new inverter welders won't have good service lives. There's no reason why they can't be designed to last for years and years. Do you think Shield Arc's $5000 (or thereabouts--I don't know) Lincoln V350 is going to crap out after ten years and need a new mainboard? I doubt it. But it is true that repairs on an inverter are basically always more expensive than repairs on a transformer. On a transformer welder, if the diodes go bad, it's between $25 and $100 to replace them, depending on how many you replace. I had to put a new fan in my welder once: $20. You get the picture. Meanwhile, a new board for an inverter may cost half as much as the inverter itself did, new. And repairs are seldom effected on inverters--just replace the part that's broke and move on.
For me, I don't care if my welder is going to last 30 years. Frankly, I don't have a lot of things that I had 30 years ago. In 30 years, I will probably either A) not be welding any more, and have moved on to some other fun thing, or B) sold this welder and bought a bigger, better, spiffier one. For me, an inverter is the clear right choice, because I get to, metaphorically speaking, drive a Ferarri.
   / A good budget priced welder? #40
Joshua what did you ever do with that old boat anchor welder you had?.. is it anchoring your boat out on the lake, or did you find a "fish"? I can't seem to get rid of mine,, Heck I even offered to lift it into their truck ( I have pallet forks:)) but so far no takers..I remember one new guy on here a while back, and he was convinced the the quality of welder was directly related to the poundage.:D It is all good folks, get what you want. Hey come to think of it, I saw a You-tube video of a guy in the Philippines welding with a stinger hooked to 110volts AC panel on the side of his house..oh, and he did not bother with a welding helmet either, he just shut his eyes when the arc got to going pretty good. High tech, Low tech, No tech.. it is all good.
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
