A little help with my OLD Kioti Hauler
   / A little help with my OLD Kioti Hauler #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
AS posted previously, when wet she'll not start, no spark, I've got a new coil and ignition module to install.
Now, she's completely dead, no lights, no radio, no nothing. Battery is at 12v and even with that and jump pack, I've got nothing.
Any ideas?
Thanks,
Joel
   / A little help with my OLD Kioti Hauler #2
If you have 12 V at the battery but no power inside for radio, lights etc. it sounds like the first thing you need to check are the connections at the starter. The hot lead from the battery goes to a starter post and then feeds to the truck. Since you have no power its not getting past the starter hot lead. There should be a hot lead coming off the starter to feed the truck power. Also check the ground cable connection from the battery to the truck frame.
   / A little help with my OLD Kioti Hauler #3
Check for a fusable link and like said a bad ground.
Chris
2005 John Deere 200C LC (A55272)
2005 John Deere...
T-POST PULLER (A52708)
2014 REMOLQUES DEL NORTE 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 REMOLQUES DEL...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
golf cart (A55758)
golf cart (A55758)
