A story I have to share...
   / A story I have to share... #11
nice story..thank you for sharing this..
   / A story I have to share... #12
Gave it a few minutes to fill up with exhaust fumes and started wire welding away on it.
Exhaust fumes mixed with oxygen to the proper ratio are explosive. Using exhaust fumes is not an accepted welding procedure.:thumbsup:
   / A story I have to share... #13
I wonder if you could accomplish the same thing with a tube running off a MIG tank.
   / A story I have to share... #14
I went to welding school for a time in the 60's. The instructor said there was one gas tank that would be safe to weld on. Take the tank off the vehicle, fill it with water. Let it sit enough years that the water caused big holes of rusted out places to appear. A few more years should pass, so that little remaining metal was evident, now it probably is safe to light your torch---or strike the arc.
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
BRAKE DRUM HANDLER (A55745)
BRAKE DRUM HANDLER...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
INOP-NON-RUNNING 2008 Peterbilt 340 Water Truck, VIN # 2NPRLN9X78M769162 (A54865)
INOP-NON-RUNNING...
2021 Premier PTX Pontoon Boat (A54865)
2021 Premier PTX...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
