A well-made, bolt-on tooth bar?
   / A well-made, bolt-on tooth bar? #11
Construction attachments makes several other styles as well. I believe Ted's brother at ETA Owns construction attachments
All my teeth are welded within about 1/16" inch tolerance all are either touching or very close. Sounds like the guy that welded yours up was on some sort stimulant
   / A well-made, bolt-on tooth bar? #13
My neighbor went with FRONTLINE TOOTH BAR 60" | Ford Distributing, with the one caveat that he did not want to drill any holes in his bucket. I believe his has 3 or 4 set screws that you snug up on the bucket, and cover each with an acorn nut. It seems to be well built, and for what we do it has performed well. Just another option.
   / A well-made, bolt-on tooth bar? #14
Iowa farms on ebay. I love mine (first one did break a shank - probably my fault, but their customer service was awesome and they sent out a new one the same day).
Very tough, made correctly to its listed size, came with bolts. Ships fast, made in USA, etc.
   / A well-made, bolt-on tooth bar? #16
I have bought them from a Skid steer dealer (for a SS). They should have one in stock, maybe not in your size, but one that should represent how one you order is built. I've been able to bend a shank (a little) with a med. size SS, but it was not during normal digging use. I agree that a tooth bucket is the better option, and a if you can find a used one at an auction, might cost the same.
   / A well-made, bolt-on tooth bar? #17
I put mine through ****, and it hasn't blinked....
Toothbars
I dug out, then rolled this huge chunk of concrete, beating up the teeth the whole time:
   / A well-made, bolt-on tooth bar? #18
Yep, definitely WR Long. Tough toothbars!!!
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
2020 ASPT 16ft. T/A Flatbed Utility Trailer (A55853)
2020 ASPT 16ft...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2020 DRAGON ESP...
10' CONTAINER (A52706)
