totouchantler
Bronze Member
I believe I will be removing my FEL loader when I finish mow (wide open 2 acre lawn). Today I practiced (several times) removing it.... Im quite good at it now
. Each time I disconnected the four hoses I noticed a minute amount of fluid escaped.... My 1st question?: Will frequently disconnecting the hoses cause problematic air to enter the Hydraulic and/or HST pump system? 2nd question?: Is it possible to overfill the Hydraulic and or HST resevoir? (rear fill cap) Or does the system work as a reservoir only taking oil as it needs it if low? I do check the HST/Hydraulic fluid regularly via the dipstick. Im just wondering if its okay to top off the oil at the fill port at the rear of the tractor? Thanks for any replies. I'm just trying to be proactive without being pro destructive..... If I continually disconnect the loader to lighten the tractor to mow the yard.... I can see fluid loss maybe being a problem? Yeah yeah yeah.... I know I should probably just buy a dedicated zero turn mower
Chris
Chris
