?? About landscape rakes
   / ?? About landscape rakes #11
Obviously you did a bit more than a lite rake over on that. :)
Three LARGE trees removed, two basement deep french drains that are 3 feet wide,,
and the land graded so the water will run away from the house,,,
Yea, more than a lite raking,,,
I ran the landplane over it before the raking,,,
The landplane made it much more level than the D3 CAT left it,, also smoother.
   / ?? About landscape rakes #12
Not sure how many trees you have, but honestly it is just as easy to use a wheelbarrow for this particular chore.
   / ?? About landscape rakes #13
That really depends on your age,, I am at the age that I do not like to pick up more than twenty things at a time,
so, a couple hundred sticks can take a month,,,, :eek:
A guy gave me an old hay rake, that did a pretty good job.
the rake tines were rubber mounted, they would flex before you lifted sod.
With that rake, I would end up with a wind row of sticks.
   / ?? About landscape rakes #14
The problem I find is that when you run over the sticks, they get crushed up into small bits. While on the stronger pieces, I worry about puncturing a $ tire.
   / ?? About landscape rakes #15
Having said that, I believe the landscape rake is about the best implement to have.
   / ?? About landscape rakes #16
In our yard running a landscape rake to gather sticks would cause too damage. A lot depends on your turf, the lay of the land, type of tines on the rake and the weight of the rake. In my case we have a lot of little humps and rolls and the rake tears them all up. I also find that lighter rakes do better in yards where heavier duty ones seems to do more damage and the tines flex less.
As others mentioned there maybe better options than a landscape rake.
   / ?? About landscape rakes #17
I second vote the pine straw rake I have one it works good on the grass picking up sticks , pine cones, leaves, and also detaches the grass
   / ?? About landscape rakes #18
Mine isn’t for the yard, it is for a few acres of field that I keep mowed with a rotary cutter, we’re I have a bunch of large oak trees that drop a bunch of limbs from 3” down. Plus a bunch of other stuff I’ve to do
   / ?? About landscape rakes #19
I use landscape rake on lawn from time to time and normally no issue damaging grass then will hit a spot that may have some damage but nothing of any important. Normally I feel the little pulled out to be opening up too thick grass. The ability to rake the sticks and not the leaves will work better with at least every other tooth removed. Might be you need to remove two of three, much will depend on the size of the leaves and sticks.
If I were going to do this I would remove some teeth in different spacing say every other one and then two of three and test it.
   / ?? About landscape rakes #20
Good chance you'll rip up chunks of grass here and there and you'll still have to pick up sticks etc.,get what you can w/rake and go slow what I do.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel Forks...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
