? about MTD 5hp. Chipper/shredders
   / ? about MTD 5hp. Chipper/shredders #11
Well you got a good thing to mulch up garden stuff,[cornstalks, sunflower stalks,etc], but don't try any 2" tree limbs with it. RICHARD GAUTHIER, EXPERIENCE
Richard, I just tried it on some stuff that was at least 2 1/2" and it ate it right up with no problems! The blades on this thing look like they were never used. I'm impressed on how fine it shreads and how fast it will chip. But it is loud /forums/images/graemlins/shocked.gif Just have to wear some muffs when using it.
   / ? about MTD 5hp. Chipper/shredders #13
Von, I hate to tell you this but you got ripped off. I feel bad for you and if I get over your way I will reimburse you the 62 dollars and take it off your hands for you, just because I am a nice guy.
   / ? about MTD 5hp. Chipper/shredders #14
WOW, the thing looks like its brand new. You got a good buy there. Happy chipping.
BTW, I HATED the bag that holds the chips. You just get on a roll chipping, then the bag fills, and you have to shut it off, and empty it. PITA. I now just chip on the ground.
   / ? about MTD 5hp. Chipper/shredders #15
You did real welll on it. I have an 8 hp tecumsa MTD that I got a good buy on about 10 years ago. I was in Costco and as I walked past I over heard the manager talking with another employee about what to do with it. The large tray had been lost . Other than that it was brand new . I asked them what they were going to mark it down to 300 and I said how about $275. The manager said ok. I have used it every year and it does a good Jub. As others mentioned its noisy when working and throws the chips a long ways. I eventually sey up a small section of chicken wire fence about 15 feet away andit does a pretty good job of catching the chips. I then shovel them into a wheel barrow and take them to where I want them. It will eat anything that will fit down its throat. Just dont let any one get in the path of the discharge. It will hurt
   / ? about MTD 5hp. Chipper/shredders #16
I have a 10HP MTD with the newer plastic chute. It worked OK from the store, but felt the chute was too restrictive for most of the branches. I was getting a workout trying to force the branches down the chute. I guess I'm just all out of straight perfect branches at my place !!
I decided to experiment and see if I could make it work better.
1) I sharpened the "new" blades. I removed them and filed them to a razor sharp edge. I used a hand file, as a power tool would probably heat the steel too much and lose the heat treating temper.
2) I hogged out the entry hole at the end of the metal chute. The factory chute is welded to the metal plate and sticks out past the bracket. I ground off at least 1/4" around the top and sides to allow larger or crooked branches to get to the blade. This 1/4" inch makes quite a difference since the metal is tapered into a cone. It adds more usable diameter into the blade.
3) I removed the plastic chute and installed the metal entry chute by itself. This leaves a chute about 10" tall.
This is a new machine !! It will eat everytihg I throw in and right now. It hardly slows down for a 3" branch. I feed them in as fast as I can move my arm. The chute is not any more dangerous than the DR style I have seen. Of course, utmost care and safety must be used at all times with these nasty machines.
I always wear ear muffs. It's a racket to behold. /forums/images/graemlins/laugh.gif
   / ? about MTD 5hp. Chipper/shredders #17
Hey, that sounds like a couple of really good ideas. I have a similar chipper, and getting branches in that $!#@ plastic chute is a real chore. I think I may just take mine apart and see what kind of modifications it could use...thanks!
   / ? about MTD 5hp. Chipper/shredders #18
Von,
I've got one looks like yours, about 10 years old, but is 8 hp. Keep the blades sharp and it will eat anything you put in it.
Bob
   / ? about MTD 5hp. Chipper/shredders #19
Picked up a MTD 5hp. chipper/ shredder today at a garage sale for $60.00. It states that it will chip up to 3" and the shredder will work on stuff up to 1/2". The guy who owned it was moving down south and everything had to go! It had not been used for 3 years and looks like new. I was wondering if anyone had one and is it any good? Or is there anything I should look out for in using it. I guess I can sell it if it's not up to the task. I sure could have used it a few months ago after the ice storm we had! (lost about 30 trees here at the antique shop) Thanks for the help.
I have the same one. I chipped up a small pile of branches too small to burn in the fireplace, and made a 4 foot high pile go away, in an hour. It worked quite well. The first thing I did is sharpen all three blades with a grinder.
The "short lawnmower" style blade, and the two conventional looking axe style cutting blades. That took about an hour also. I like the fact the engine is small enough I can start it the two or three times a year I will use it.
I will still rent a big 14 hp unit self feeding for large 4" logs and such. This unit says up to 3 inches in the smaller drop in chute, but it chews the 3 inch, slowly. I just put it in and started raking some more branches up.
I will limit its use to getting rid of piles of branches and creating compost from the leaves, which is what I do mostly. They work wonders in the garden, and must be sliced up this way to create good compost, by next summer.
Its is a solid unit. I am satisfied with MTD 5 hp chipper/ shredder.
   / ? about MTD 5hp. Chipper/shredders #20
I have got one that is about 10 years old also. It has chipped alot of hard and soft wood and been really faithful. Like others said, keep your blades sharp and you will be good to go.
Land Honor Skid Steer 3 pt Adapter (A50515)
Land Honor Skid...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
HOMEADE 4 BOLSTER LOG TRAILER (A51243)
HOMEADE 4 BOLSTER...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
3400 (A47384)
3400 (A47384)
