??? About Purchase, Care and Tack for Miniature Horses
   / ??? About Purchase, Care and Tack for Miniature Horses
What are the three best types of hay for horses especially mini horses if they have different hay requirements.
I picked up three bales of timothy hay at TSC just to be safe and when short on grass they eat it fine but will go for green grass first. :)
Any thoughts on amounts needed for two that are about 250 pounds two at 1 one year old next Mar/May?
I have an old 6x25' equipment trailer that I may put it on. I am thinking of getting some round bales to save so much handling of square bales. I can tarp it on the trailer and it will be 30 inches off the ground. May need to keep it close to the house.
   / ??? About Purchase, Care and Tack for Miniature Horses #22
We feed a half flake of timothy/alfalfa mix per day. They also get one carrot and an half an apple each morning and cup of mini horse feed in the evenings. The mare - Peach - weighs just under 200 pounds, is 3 years old, and stands 28". Trouble is 31" tall, weighs about 220 and is 2 years old.
   / ??? About Purchase, Care and Tack for Miniature Horses #23
G'day Mate & congratulations.
I know you've said that you have past experience with stock so I'll just let you know of a few experiences I've had with my boys & setting up the property for them.
I haven't seen you posting about water... They're going to need a lot of fresh water & a garden hose to a portable, automatic, trough is essential. I say portable because you'll be shifting it everytime you shift grasing paddocks.
If you're going to feed by round bale I have a couple of suggestions: 1) have it in a 'restricted' area that you can limit their access to it, and 2) set up some sort of hay ring or else they will barge through the round IOT get at 'the good stuff' in the middle. They will then foul the hay that they've barged through.
Have your local equine vet come out soon to give them all a once over. This is a good practice 'cause he/she will be able to assess them whilst (hopefully) healthy as opposed to attending them when something's wrong. Plus the fact that you bought them without a vet check; this will give you 'peace of mind'. In particular & very important, have their teeth at least looked at because everything can look great on the outside but dentistry is often overlooked.
Bit of a story on that note... I bought 'Jack' as a companion horse for my riding horse 'Treat'. Jack was a cheap 'throw in', almost a rescue, but had a lovely nature. When the vet had a look at him it was discovered that he had the most extreme case of Parrot Mouth that the vet had ever seen! Jack now gets a wee bit of extra care (carrots need to be broken into bite size pieces and hay always has to be available as opposed to straight grasing) but he's still the most gentle natured horse you could want.
Best of luck with your new children.
   / ??? About Purchase, Care and Tack for Miniature Horses #25
I keep hearing this. Does this mean I need to bushhog off a new pasture area so they can not eat it so fast? If they are in a new pasture how do you stop them from eating too much. With this only occur the first few days or that they had been hungry of weeks before getting to a new lush pasture. They now graze about all of the time but it is so short they can not get too much at a time. If they swallow really long blades of grass is that the problem?
One mare was trying to eat dirt when we went to look at them (assumed a block of salt had set there before) and in about two days she had eaten a brick size block of mineral salt but she is not licking like at first. The other mare did not but did lick some.
Alot depends on how lush the grass is. All most all horses need pasture regulation when the spring grass emerges and is overly rich in nutrients compared to the dryer summer grass but the lushness can continue into summer with lots of rain. To much grass protein, etc. can lead to colic or laminitus or simply to much body fat. I know that ponies and older horses are more prone to grass issues.
They won't like it but sometimes you have to allow them to graze a few hours then put them on a dry lot, ie; no grass for an equal period of time. Make sure there are no toxic weeds on the dry lot else they will eat them as a last choice. Grass length in itself should not matter. To long and it gets bitter which may help limit the intake but more than likely will lead to overgrazing one area and ignoring others.
Some horses actually need to wear a grazing mask that limits their intake. Some will eat dirt just to have something to eat or because the lack some sort of minerals.
Though I do have one larger pasture and several smaller ones, the ideal is to have similar paddocks or grazing areas. As one is grazed down but not out, move the horses to a new area, cut the grazed one and keep them off while it recovers and to keep them from eating the clippings which undergo chemical changes but will soon dry out. (You probably know but I will mention anyway, never ever dump grass clippings in their pasture or paddock for them to munch on)
You want your paddocks to not be too short and not to weedy. The grass will vary in length but should be relatively similar in color so the horses diet remains the same.
Don't let your baled hay run low then bring in a new batch. Blend a little old with the new especially if you switch to orchard from timouthy. I don't know but I would think that you should never feed alfalfa or an alfalfa blend hay to the mini's. Too much protein. Same with any grain if you are giving any. Consistant type and amounts with slow changes are an absolute with grain. With so much grass, they probably don't need any grain right now anyway.
We put salt blocks in our horses stalls so they have free choice. Some horses will consume much more salt than others with no issues. The vet or someone else who knows may suggest different for the mini's. Don't use a cow tub.
   / ??? About Purchase, Care and Tack for Miniature Horses #26
I just had a thought that is not so pleasent but a current coggins test is required for equines being brought into KY. You should mention this to the former owner and also ask about what shots they may have had and when. Get the vet out and get them up to date as needed. West Nile for one is a real threat. Also ask about a worming regument if any. They will need a rotational routine worming. If you have never done this, the vet can show you how so you can do it yourself going forward. The vet can advise a schedule and how much to give.
   / ??? About Purchase, Care and Tack for Miniature Horses #28
mini's need very little as far as pasture and hay
they can colic quit easy (and you don't want that vet bill)
We leave ours in a mud lot and put her out maybe an hour to hour and a half each eve
she gets a half a flake of hay in twice a day along with a hand full of oats
Now mini's can be very nice animals but put them with the big horses and you would think that the big boys would push them around. NOT SO
mini's have a draft horse attitude around larger horses
I thought that it was just ours until we go to the county fair and I see all the little ones trying to kick and bite the big guys
Its rather fun to watch
We got started worming and found some enclosed papers with testing results so that is a good start. Is colic and foundering two different conditions? I just did not know horses would founder on just open pasture and water which is typically what I see when looking at other operations. Ours are eating more hay as the grass gets shorter. The time of the one mare spends at the mineral salt block is just a fraction of time spent there the first two days.
   / ??? About Purchase, Care and Tack for Miniature Horses #30
Too much grass is a bad thing. Yeah, I know, kind of weird. Colic and Founder are two separate conditions. Colic is internal - intenstinal, founder is "external" - hooves. Both can be deadly conditions, and well, it is best to read up on them.
I have one that is prone to colic,and it requires, pasture management time.
The horse gains comfort in chewing, even in distress it will chew, "eating" itself to death.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
