AC-DC Miller Thunderbolt Welder
   / AC-DC Miller Thunderbolt Welder #1
ecbaatz
Honor MI
Branson 2400H
I found a posting on craig's list for a AC-DC Miller Thunderbolt welder. The seller is asking $300 for it. It sounds like a good price as new on line is $653. But my question is, is this a good welder and even better is the price reasonable?
Welder-AC-DC Miller Thunderbolt
Thanks for the help,
Eric
   / AC-DC Miller Thunderbolt Welder #2
Eric
I have never welded with one, but I have heard they are pretty decent. You have continuous control of current instead of steps that are often too cold or too hot.
   / AC-DC Miller Thunderbolt Welder #3
I think everyone on this forum has a stick machine. I'm not familiar with that one so I would ask what is the max amperage output? Most of my stick weld projects are on 12ga steel and thicker so I use around 130A- 175A most often, but it's good to have 200A or more available for heavy implement repair. So, I guess it depends on if you'll do more sheet metal work or heavy fabricating like building trailer frames etc.
   / AC-DC Miller Thunderbolt Welder #4
I bought a new one a few years ago. Wonderful machine.
   / AC-DC Miller Thunderbolt Welder #5
I like mine...it does what i need it to do. I replaced the cooling fan in mine but other than that it has had no problems. I paid 1/3 the price they are asking...bit mine looks uglier than that one.
Thank you all for the replies. I will have to go look at it.
   / AC-DC Miller Thunderbolt Welder #7
I'm sure they are great welders and will serve you well. I might suggest if you don't purchase the Thunderbolt is to watch Craigslist or your local sources for a used Miller Dialarc 250 or Lincoln Idealarc 250, these are truly commercial grade machines that can be had in the $400-$600 range used and will literally last a lifetime. They will run fine on a 50 amp service if you have that available. I just bought a 1960 Lincoln Idealarc 250 recently that looked rough cosmetically but welded great. Just a suggestion
   / AC-DC Miller Thunderbolt Welder #8
I agree. I recently picked up an Idealarc 250-250 with 50' leads for $$300.
It welds really nice. It's currently one of my restoration projects.
Here's a pic of it after pressure washing.
Terry
   / AC-DC Miller Thunderbolt Welder #9
I think you could drop those Idealarcs out of an airplane, and they would still work. Only thing I've ever heard that seems to go wrong with them. Is the on / off switch goes out, but generally not for the first 100-years.:laughing:
I have a 1937 Idealarc 300, still welds like a dream!:cool2:
   / AC-DC Miller Thunderbolt Welder #10
Restoring a welder in the age of throw-away-n-buy-new. Well have you ever hand re-wound the stator on a 1976 Craftsman 10" Radial Arm Saw? Was my favorite shop tool and the new ones are crud.
And here is the schematic I made for anyone else so inclined:
Cushman Cart (A55853)
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
Ford 8510 (A53317)
Ford 8510 (A53317)
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
