AC-DC Miller Thunderbolt Welder
   / AC-DC Miller Thunderbolt Welder #11
I think you could drop those Idealarcs out of an airplane, and they would still work. Only thing I've ever heard that seems to go wrong with them. Is the on / off switch goes out, but generally not for the first 100-years.:laughing: I have a 1937 Idealarc 300, still welds like a dream!:cool2:
Nice. I need, I mean want one of those. :D
Terry
   / AC-DC Miller Thunderbolt Welder #12
Restoring a welder in the age of throw-away-n-buy-new. Well have you ever hand re-wound the stator on a 1976 Craftsman 10" Radial Arm Saw? Was my favorite shop tool and the new ones are crud. <img src="http://www.tractorbynet.com/forums/files/welding/426948-ac-dc-miller-thunderbolt-welder-0602121540-00-jpg"/> <img src="http://www.tractorbynet.com/forums/files/welding/426949-ac-dc-miller-thunderbolt-welder-0603121930-00-jpg"/> <img src="http://www.tractorbynet.com/forums/files/welding/426950-ac-dc-miller-thunderbolt-welder-0609121505-00-jpg"/> <img src="http://www.tractorbynet.com/forums/files/welding/426951-ac-dc-miller-thunderbolt-welder-0611121319-00-jpg"/> And here is the schematic I made for anyone else so inclined: <img src="http://www.tractorbynet.com/forums/files/welding/426952-ac-dc-miller-thunderbolt-welder-saw-motor-stator-jpg"/>
Thanks, Fawken. I just printed the schematic for reference.
Terry
   / AC-DC Miller Thunderbolt Welder #14
   / AC-DC Miller Thunderbolt Welder #15
The new ones don't have a threaded shaft for attaching a drill chuck- plus they're made in China. I built a house with mine and remodeled another. I have the blades that let you make crown molding, cabinets, and base boards. The drill chuck I use for polishing wheels and sometimes a long travel, horizontal drill press.
   / AC-DC Miller Thunderbolt Welder #16
Fawken. Both my motors have the threaded shaft. ( had to look) :)
Terry
   / AC-DC Miller Thunderbolt Welder #17
Great get a 1/2" chuck and you can do some polishing and grinding or even high speed drilling. I believe these saws were made by DeWalt in NY. There is a start capacitor that can go bad, but what I usually see is the on switch or the start relay become high resistance and cause the coils to overheat.
   / AC-DC Miller Thunderbolt Welder #18
That is just plain cool!
   / AC-DC Miller Thunderbolt Welder #19
Last month I saw a Miller DialArc250 nearby on CL. I had been looking hi and low for weeks. The guy had two other bigger rigs, a Lincoln SA-200 and another one IdealArc400 maybe, about the size of a deep freezer. He got them at an estate sale, with some guys other toys that he won't be needing anymore. We had no way to test the welder, but I figured it had enough metal in it to get some $ back at the scrap yard if it was a total loss. I offered $300 and he kinda consternated a bit while kicking a pebble or something and took it. From my standpoint it could be a boat anchor, but it had that $300 retail wheel kit on it so money changed hands and he help me push the monster into my trailer, take it home. My Mrs picks up my materials order and I spend a few hours during the week to wire in a 50A circuit from the panel. TIP: Put the wire in hard conduit and don't try to save a few pennies with 1/2" conduit, step up to 3/4" conduit. Then you don't have to curse your cheap *** during an hour of wire pulling on an otherwise easy job. The DialArc had a crap 30A plug on it that the former owner partially cut and bent the prongs on to fit into 50A receptacle..WTF?!! You get that big welder then cut down on the juice running to it? I replaced that with a legitimate 50A plug too.
I also opened up the welder and used contact cleaner on all the important bits, and vacuumed the dust out of it. Flipped the switch and presto!!...the fan started to whirr and I made my first stick bead. All in I spent about $400 including materials for the circuit. I replaced the sticker with one from Harbor Fright and that helps me pull off my stuck rods better :) So far it runs great, and I didn't spend any more than I would have for a buzzbox at the Orange Portal to H3LL.
My only advise is to be patient, and hold out for a AC/DC rig. The YouTube has a lot of videos to help you out.
2014 International Maxxforce DT (A53317)
2014 International...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
ELECTRIC GOLF CART (A55745)
ELECTRIC GOLF CART...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
Red Military Truck (A53422)
Red Military Truck...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
