Accessory plug on Kubota?
   / Accessory plug on Kubota? #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
Somewhere I read there is a tied-off accessory circuit on the back of Kubotas. If so I'd like to use it for some LED lights.
Anyone know for sure?
   / Accessory plug on Kubota? #2
At least on my cabbed version;it was bundled with the caution lights.It may be the same on yours,remove the tape wrap at the bottom of the caution lights,I think they are prewired for a switch also.
   / Accessory plug on Kubota? #3
For the L3200' it's under the left rear fender. There is a connector (bullet style I recall, female) taped back against the harness to the rear lights. Just remove the little piece of tape and go!
   / Accessory plug on Kubota? #4
Under the left fender. On mine its female spade connectors in a T shape. I used it briefly to wire up 4 LED spotlights on my ROPS.
I ended up drilling a hole in my dash, ran wire there & tapped into or near the fusebox. Made for a nicer switch location.
   / Accessory plug on Kubota? #5
Mine is tucked up under the dash on the left side. It a female spade plug on the end of about a foot of wire. It is strapped up with some other wires right next to the fuse box. I only found it by accident when doing routine checking of the fuse box. It is actually shown in my owners manual.
Tada! Got it! I'm going to put a multimeter on it, I assume it goes on and off with the other lights but that's fine.
Didn't find a pigtail on the fusebox but I have hope....
   / Accessory plug on Kubota? #8
That aux/work light circuit is independent of the other lights. The wire runs to the fusebox and already has a fuse. So you just need to hookup in the rear and that's it.
   / Accessory plug on Kubota? #9
Ah, Ha - it can't hide forever. Kind of like a snipe hunt - ha,ha. Mine is independent of all other lights - its on/off with the ignition switch.
   / Accessory plug on Kubota? #10
Same here, ignition switched, not switched with headlightslights. Which is why I put the new switch in the dash for my ROPS lights. Given how bad the headlights can glare off the bucket having the ROPS lights on their own is nice. I thought about 2 switches for the front facing lights & a different switch for the rear lights, but went the easy way with 1 switch & have had no regrets.
2021 Chevrolet Silverado 1500 Pickup Truck (A56858)
2021 Chevrolet...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
17201 (A55852)
17201 (A55852)
40' CONTAINER (A52706)
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
