Dr_Zinj
I occasionally catch myself driving with the parking brake engaged on my Bobcat CT230.  Of course the parking brake is the regular brakes only with the catch lever engaged.  In low range with the tach running 2K and you'll barely notice until you smell them cooking.  Middle range and you'll notice quickly.  High range and it will stall the engine out before you go anywhere.  If flames are coming from the wheels, then you overheated your brakes.  If you can set the parking brake and leave the tractor on a slope in neutral and it stays there, you're okay.  The best I can say is double check every time you go to use the forward or reverse pedal.  It's better to set the parking brake and forget you left it on, than to hop off the tractor without it.
