TCJatko
Platinum Member
Acetone does have a low flash point (the temperature at which it produces flammable vapors). It also burns with an invisible flame like alcohol. Tricky stuff.
Yes, but gasoline dissolves oil forming a solution. Acetone OTOH, forms a suspension with ATF. You have to keep it shaken up or it settles out. Such has ~no effect on vapor pressure and thus flashpoint.larry
Intresting. Which works best? Also bringing up the point - why not gas and ATF? Perhaps its the thinness/lo viscosity of the ATF acetone solution above the part that will settle out ... and if so; What %ATF will form a solution with acetone? Beyond that are we wasting ATF?now that, there, could be an issue.
When I mix up atf / acteone, I generally put in a couple of other things just for that reason right there, a different solvent. hexane, naptha, etc so i don't have to set and constantly shake it. I like soloution way better than suspension or emulsion.
I've been using the 50/50 mix since I heard about it on a certain (unique) car forum...probably 7-8 years ago...
I keep the mixture in a mason jar with a good seal and pour it into a pumping oil can when I'm working on something requiring it...if your container does not seal completely the acetone will evaporate away over time....
Myself, I try to avoid storing such volatiles in glass containers...camping stores sell aluminum fuel "bottles" that work well.
in my atf/acetone coctail, i found nason medium reducer or hexane made a stable mix..
Acetone is an excellent water displacer. I used to work for a geochemistry professor who used acetone to remove water from samples. He'd wash the sample in acetone and then let the acetone evaporate so that the pulverized rock had zero moisture. Of course, the guy had no common sense about safety. I caught him putting acetone into the same storage cabinet as perchloric acid. Any organic solvent in the same cabinet as any acid is a no-no, but reagent grade perchloric acid will explode immediately when it comes in contact with organics. This same professor had a scar on the back of his hand where he carelessly came into contact with perchloric acid. Despite his carelessness, he was a brilliant scientist who discovered micro-craters in Moon rock samples. But to stay on topic, acetone's ability to displace moisture may be one of the reasons it works so well with tranny fluid as a penetrating lubricant.
Interesting.
What about diluting the AFT-acetone mixture with mineral spirits or turpentine (organic)? Would this be a problem?![]()
