Actual cost of firewood
/ Actual cost of firewood #181
There is a major misconception about creosote and what causes it...
Hardwood can cause creosote buildup just the same as pine...I know people that have only burned oak and had a flue fire because of creosote...
It is all about moisture content...a live tree cut and split can (depending on ambient temp.and humidity) take over a year to get an internal MC of 15%.
Trees that were downed or dead standing will be different depending...
Green or wet wood will burn but the moisture is going to be released as vapor along with carbon elements and will condense as creosote as it cools...
Moisture meters will not give accurate readings on a typical split etc...a partially seasoned split may read 15% or less on a meter but toss it on a fire and watch as the outer 1/3 burns like seasoned wood should but then it just starts to smolder...
Yes, agree they all can and will build up and at times may catch fire... seen many chimney fires and we seldom burned pine. But we did burn some and especially to get a fire started.
This is a good link that has some good info.
Burning Pine in an Indoor Wood Stove | Home Guides | SF Gate
/ Actual cost of firewood #182
The outside is the driest part. You need to split a piece in half and measure the fresh split edge to get an accurate measurement.
/ Actual cost of firewood #183
Agree 100%. I don't like pine because it has low BTUs, but if dried properly it doesn't make any more creosote than other woods of comparable moisture content. Creosote is all about moisture content, steam, and cooling down the smoke.
/ Actual cost of firewood #184
Black pine is pretty decent wood. It’s as dense as soft maple or any similar wood. It has viscous pine cones though. White pine is pretty much useless and has a lot more sap. That’s about the only pine that grows here aside from decorative evergreen trees.
/ Actual cost of firewood #185
Each year I would pick wood for the Christmas fire... it was a tradition and I became known for my Holiday fire before the burn bans.
The key was really dry hardwood... that was it.
I would place the selected wood in a warm/dry place for 8 to 9 months...
On the other side... I have lots of problems in rentals with fire places... just because it "Burns" doesn't mean you should burn it... subject for another thread.
/ Actual cost of firewood #186
There’s plenty of people those of us that burn responsibly can thank when wood stoves are banned entirely. I like to think that it’ll be a ways out here, but those you in more blue states are running that direction. It doesn’t even matter if it’s hardwood. And in lumber terms really dry isn’t important either. Unless you leave live in the desert wood will never season without a roof and will never season un split.
/ Actual cost of firewood #187
I try to burn my poorer wood in the shoulder months where I don’t need as much heat. I toss it to the side during the fall and winter and then burn it in late winter and spring.
/ Actual cost of firewood #188
About 90 percent of of my firewood is oak. The rest is whatever I come across and white pine is the only one I toss on the brush pile. I burn the “softwoods” and irregular shaped pieces when I’m at home to put more on shortly after. I burn the straight oak piece when I’m going to bed or work. That’s just the general plan. I’m not a firewood police that gets bent out of shape if a softwood piece gets in my night load or a straight piece of oak gets burned when I’m home.
/ Actual cost of firewood #189
Are you burning mostly Fir?
/ Actual cost of firewood #190
Well my neighbor just had a 'chimney fire'. He said that the wood was real dry but I know that it was all 'crap wood', like spruce or balsom.
Well he had so much creosote build up that the flue ignited and as a result the rafters caught fire and the damage is so extensive that I believe his house might be a total loss. All his exposed rafters are charred, the metal roofing was ripped up by the firefighters and the insulation totally soaked. Even the fireman's water ran down the walls and the siding is water bulged.
Naturally he never had the flue swept either.
The downside is as luck would have it the firefighters only took 20 mins to respond thus the building is still standing along with their carnage, (they love to chop and hack, don't they)
With winter totally set in and the fact that first thing they did was cut the hydro power his entire water system is now totally shot from plumbing to water tank and pumping system.
My comments to him was that hopefully the insurance would be able to declare it a total loss.
Sad as they really did a nice job to update a questionable DIY cottage.
(I know that cottage well as the previous owner asked me to do some additions which I refused to do as I honestly believed he would have thrown good $$ after a bad situation. (I could go on))
Moral is if you burn wood, know what you are doing. Sweep often or burn hot* but get rid of that creosote as it can cost you your house.
*occasional 'hot' can actually burn off creosote under controlled conditions. (been there done that LOL)
/ Actual cost of firewood #191
This is a good idea!
/ Actual cost of firewood #192
Fir, Maple and this year a fair amount of Hawthorne from fencerows. A little Alder as well. All of those are about the same, my poorer wood comes from wood that has aged too much or was just semi punk wood that ended up in the woodpile. Next year it will be almost all fir. Just depends what trees I cut 2 years ago.
/ Actual cost of firewood #193
I'm mostly Fir with some Alder and Cedar...
Probably 95% Fir as had some large storm fall trees in WA
In Oakland CA you can probably guess it is all Oak.
/ Actual cost of firewood #194
If the insurance company pays for it all then it doesn't increase the actual cost of the firewood at all...
/ Actual cost of firewood #195
Gas furnaces have malfunctioned and poisoned people with carbon monoxide. Throwing in malfunctioning equipment usually caused by operator error isn’t a fair assessment.
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
