OP
John Joseph McVeigh
How did you like it???? How far did you get it to blow and at what RPM?
I conducted all operations at Wide Open Throttle.
I spray the inside of my blower and chute with Silicone spray -- that helps. We have a gravel state road and the main problem comes with the gravel being picked up where they have plowed. The gravel even takes off the powder coat finish -- you end up with bare metal. We now have a Blacktop driveway and if that was all I had to do -- the blower would be a much happier camper !:thumbsup:
At what rpm?
Typically, the tach read 3400 rpm. The tach reading dropped to 3,000 rpm as I was simultaneously climbing the infamous S-Curved Hill and running the snow blower simultaneously. I adjusted the forward speed as I was climbing to keep the crankshaft rpms within that range.
John, you can probably get by with just a set on the rears but I would not go with v-bars though. They will mark up your asphalt and concrete floors. I run a set of 2 link cross chains on the rear of mine when the snow starts to pile up or when it starts to get icy. I have v-bars for my bigger tractors and also a set of v-bars that will fit the steiner if I need them. All my plowing is gravel and grass with just cement aprons and cement floor that v-bars do damage when used. I had to get larger chains and remove some cross links to fit the Steiner. This is the best picture I have of mine. All of my chains I have bought at Tirechains.com.
Yes, I used silicone spray lubricant to treat the walls of the bucket, the face of the impeller, the auger, and the inside walls of the chute before setting out. I used up one partially full can (Solder Seal brand) that I had had for I don't know how long, and used part of another one of three cans that I had bought at the local Ace Hardware a few weeks ago. Those were the Ace house brand.
Fortunately, I do not have to deal with gravel.
BKB, I have come to the conclusion, as the result of the last two storms, that I could use a set of axle extensions and chains all the way around. I have the link to the site from which you purchased the V-bar garden-tractor chains, and I will be following up on that. I understand from what you have previously written that you ordered extra sets of cross-chains to achieve two-link spacing. Did you end up using any of the extra cross-chains that you ordered? Any particulars would be greatly appreciated.
Best,
JJM
John, how is that mower working for you? Any problems with grass in the radiator?
Well bought my snowblower in August and just finished cleaning the driveway for the first time. I was a bit disappointed
as it took about 10 minutes and not enough seat time. Over the years I have used the angle blade to clean it and would of taken about 45 minutes. Driveway is clean down to pavement so just as good as with the blade and no banks. One thing that I did notice was the weight transfer was not engaged when I started and had a hard time turning. Overall, wow should have bought one years ago.
How did you guys make out with the Blizzard of 2016? I have a 1/2 mile gravel driveway and currently use a 26" walk behind to clear about 1/3 of it,takes 5 passes to get open wide enough, neighbors usually help with the rest of it with various 20-45hp tractors with buckets and blades, I open it up wider with the Case backhoe. I would love to have a snow blower for my Steiner but they are too expensive new, I have seen a few used ones but they are like 7 hours away and $1200-$1700. I was thinking of mounting a Sears or similar 46"-48" snow blower to it, much cheaper, but not sure if they would hold up to the Steiner.
Having used a 24-inch walk-behind, I can appreciate the amount of effort that you expend. My paved driveway has three widths: 12 feet for the longest run, 19 feet on a steep slope with an S-Curve, and 35 feet up near the house. Even if there were no spillover, it took a lot of passes to clear that driveway.
If you add a Sears or similar snow blower to your Steiner, would it have its own power source? If not, how would you deliver mechanical power to it from the Steiner?
