Adapter Skid Steer Quick Connects to Kubota Tractor
   / Adapter Skid Steer Quick Connects to Kubota Tractor #1
z0lt3c
Hunterdon Cnty, NJ
2020 Kubota BX2380
Hoping somebody can point me in the right direction.
I recently acquired a backhoe that was most recently used on a skid steer with a remote hydraulic connection using the standard skid steer flush face couplers. It has one male and one female flush face fitting which I need to attach to my Kubota rear remote hydraulic loop.
My Kubota loop has two female AG style quick coupler fitting. They appear to be perhaps 1/4" smaller then their skid steer counter parts, and of course use two different connection systems, and dont line up male/female.
I'm not sure how to adapt these connections. I tried to take the flush face fittings off the end of the backhoe hoses, but i couldn't get them to budge.
Is their a specific adapter available for this use case? Do I need some custom hoses made to either replace the backhoe hoses or create a transition hose? Can I just swap out the AG connectors on the Kubota rear aux plate for flush face connectors?
Thanks,
   / Adapter Skid Steer Quick Connects to Kubota Tractor #2
If it were me, i'd remove the flat faced connectors and buy a pair of pioneers to match the connectors on your trctor. If they wouldn't loosen, you need longer wrenches.
   / Adapter Skid Steer Quick Connects to Kubota Tractor #3
If you can't get the hose ends off, try double wrenching them. You can probably find compatible ends at a hyd. shop. I would be more concerned about the tractors hyd. flow being enough to run the hoe.
Sincerely, Dirt
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
1999 GMC C7500 Mason Dump Truck (A55852)
1999 GMC C7500...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2018 Chevrolet Malibu Sedan (A55758)
2018 Chevrolet...
Golf Cart (A55853)
Golf Cart (A55853)
