You will have to search through the parts book. Here is a brief blurb of text. Backhoe maybe a 9250 on th 401A ?
While it isn't correct. There have been countless closed center hydrualic valves connected into open center sydraulic systems and used. While relief valves hissed and the oil heated up. Has been a few busted componets too if there wasn't a pressure relief between the pump and closed center valves.
BACKHOE CONTROL VALVE
(9250-A BACKHOE)
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 U41161 PORT PLATE 1
2 ........ O-RING 14 (A) (SUB FOR U11326, THIS APPLICATION) ( T68666 NO LONGER AVAILABLE)
3 ........ O-RING 7 (A) (SUB FOR U15415, THIS APPLICATION) ( T68667 NO LONGER AVAILABLE)
4 AT62848 SPOOL VALVE 2 STABILIZER, (SUB FOR AU41882)
5 AU41885 SPOOL VALVE 1 CROWD
6 AU41883 SPOOL VALVE 1 BUCKET
7 AT34643 SPOOL VALVE 1 SWING
8 AT35260 SPOOL VALVE 1 BOOM
9 U41160 END PLATE 1
10 12H303 LOCK WASHER 5 5/16"
11 U41173 CAP SCREW 5 5/16" X 12-3/4"
12 T36283 ORIFICE 1
13 U11426 ORIFICE 2
.. AT62847 SPOOL VALVE 1 SIX SECTION, CLOSED CENTER, (SUB FOR AT36180 AND AT59153)
.. AU40972 O-RING KIT 1 SECTION REPAIR
